YPAO mic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-28-2014, 08:21 AM - Thread Starter
Nexgen76's Avatar
Quoted: 420 Post(s)
Liked: 99
YPAO mic
I need one for a Yamaha RX-V675 but i can't tell if the one on ebay work with my model...Where can i buy one...Thanks(links).
JVC DLA-RS400U
Sliver Ticket 120' Grey screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build).
Pioneer Elite SC-85
Philips BDP7501 4K UHD Player
Ported Primate SI 18" HST subs x 2(DIY)
Nexgen76 is offline
post #2 of 4 Old 07-28-2014, 10:53 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I don't know if there's different model numbers for different receivers. Only way I know to be sure would be to order direct from Yamaha
They all connect the same way and I have owned 5 receivers with them so I feel somewhat confident saying that. It seems simpler for Yamaha to use the same spec for all of them and have the receiver software "calibrated" for the same frequnecy response.
They all look the same, indicating that they could be all the same. I was always curious myself having 4 or more laying around and wondering if there's any problems with intermixing them
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 4 Old 07-28-2014, 12:44 PM
WestCDA's Avatar
Quoted: 66 Post(s)
Liked: 78
I bought an open box Yamaha a few years back with no accessories, and had to buy the remote, AM/FM antennae, and the YPAO microphone. After searching around, I finally gave Yamaha (Canada) a call - I was amazed at how cheap the parts were to buy directly from them. I had found an online supplier for a used remote, and Yamaha sold me a brand new one for a fraction of the money they wanted. IIRC, the YPAO microphone was only a few dollars.
WestCDA is offline
post #4 of 4 Old 07-28-2014, 02:42 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
I've got two Yamaha mics they are slightly different.
fatbottom is offline
