Monoprice 2-Channel 300-watt amplifier - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-30-2014, 09:20 AM - Thread Starter
sulakd's Avatar
Quoted: 40 Post(s)
http://www.monoprice.com/Product?c_i...seq=1&format=2
No reviews yet, so I think this is a new product. Has anyone seen/heard this amp? Seems like a good price, consistent with Monoprice's other offerings generally. Description from Monoprice website:
"2 Channel Amplifier - 300 Watts - NO LOGO
Get large amounts of incredibly clean power for a stereo speaker zone in a multi-zone home audio system using this 2-Channel, 300-Watt amplifier from Monoprice!
This stereo amplifier puts out 150-watts per channel into 8-ohms with only 0.2% Total Harmonic Distortion plus Noise (THD+N)! When bridged into mono mode, it can deliver up to 470-watts into an 8-ohm load, with the same 0.2% THD+N, making it well suited for high power applications. It also boasts a -103dB signal-to-noise (S/N) ratio at the full rated power into a 4-ohm load. It also features > 65db crosstalk at the rated power into an 8-ohm load.
The amplifier has two stereo inputs with automatic switching, both of which support either line or speaker level input. The secondary input is intended for normal use with the primary input off. Then, whenever the primary input is active, it will override the secondary input. Additionally, it features a line level secondary output, which passes the secondary signal on to another amplifier or line level device.
The amplifier supports a 12 volt DC trigger for turning the amplifier on/off and a 12 volt DC trigger output to control other devices, such as a projection screen or curtains.
The volume control on the front panel is a volume attenuator more than a direct volume control. When setting up the amplifier, you set the maximum volume level using controls on the back panel, then you use the front panel attenuator to control how much of the preset volume is used"
sulakd is offline
post #2 of 11 Old 07-30-2014, 09:30 AM
Sam1000's Avatar
Quoted: 59 Post(s)
Class D or A/B? what's the dynamic range? Specs on their site are incomplete.
Pioneer/TAD S-1EX, S-7EX, Ascend HTM200
Marantz 8802A, Devialet D400 L/R, NAD M27, Squeezebox
Sam1000 is offline
post #3 of 11 Old 07-30-2014, 12:43 PM
M Code's Avatar
Quoted: 716 Post(s)
Liked: 419
It is Class A-B..
My question is what is the power bandwidth
I see frequency response but this is taken @ 1W..
Interesting features but for installer applications it is lacking some things such as an EIA rack adapters....
Also what is the warranty?
Just my $0.03...
M Code is offline
post #4 of 11 Old 07-30-2014, 01:42 PM
uncola's Avatar
Quoted: 43 Post(s)
Liked: 37
interesting.. price looks good.. maybe a rebadge of a jaycar amp or something
Gear list: Main setup - Kef Q900, Svs sb12-nsd subwoofer, onkyo 609 receiver, epson 8350 projector, elitescreens sable 92" screen, mac mini htpc
Bedroom setup: Philharmonic Audio New Philharmonitors, Odyssey Kismet Monoblocks, Soekris Dac, Hattor active preamp
uncola is online now
post #5 of 11 Old 07-30-2014, 01:53 PM
SoundChex's Avatar
Quoted: 350 Post(s)
Liked: 295
The rear apron looks a lot like an AudioSource AMP300 (or AMP310).
_
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is offline
post #6 of 11 Old 07-30-2014, 02:19 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
The input sensing was a feature on some Audio Source amps, so SoundChex may be onto something
"But this one goes up to 11"
MichaelJHuman is offline
post #7 of 11 Old 07-30-2014, 11:25 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
comparing pics and specs, this monoprice amp sure seems like a clone of an audio source amp 300, which is a clone of an OSD Audio amp.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #8 of 11 Old 07-31-2014, 01:35 AM
chalugadp's Avatar
Quoted: 1670 Post(s)
Liked: 1505
At that price I'd get inuke3000dsp. 7 times the power and DSP.
chalugadp is offline
post #9 of 11 Old 07-31-2014, 09:05 AM - Thread Starter
sulakd's Avatar
Quoted: 40 Post(s)
Yup, looks like you guys nailed it. AudioSource AMP300. Thanks!
sulakd is offline
post #10 of 11 Old 08-18-2015, 08:00 AM
riverboa's Avatar
Sorry for raising this old thread. Has anyone tried this amp from MonoPrice?
I own an old (via craiglist) Russound X225 that looks exactly like it - I've been happy with the Russound, just wondering aside from the exterior (which is exactly identical) if the internals are the same.
As other mentioned, there seems to be a lot of iterations of this amp under different brands.
riverboa is offline
post #11 of 11 Old 08-26-2015, 10:43 AM
russelms's Avatar
Liked: 0
I purchased this to power my front L+R in an 11.2 setup and it has worked out well. For the last 4 months I had been using the Denon 4520CI to power L+R and left this disconnected since moving to this the rest of my channels picked up and the front L+R compete well with the Denon's internal amp's.
For ~$250 that I paid when I bought it I couldn't be more pleased.
P.S. I had to wire my AVR pre-outs to secondary line input and use the +12VDC trigger to turn the unit on/off. Also for some reason my front LED is red when on and orange when in standby, it is supposed to be blue when on but i've never caught it change.
russelms is offline
amplifier , Monoprice
