Question about Denon avr-x1000 receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-01-2014, 03:04 AM - Thread Starter
Liked: 0
I was wondering if this receiver would work well with my setup, which is:
Fronts - def tech StudioMonitor 350
Center - def tech cs-8040hd
Surrounds - def tech promonitor 800
Subwoofer - supercube 2000
This receiver has all the features I want, so the only thing I'm concerned about is the sound quality it will provide. Will its power output be enough to power my speakers? Will this receiver provide high quality sound in comparison to the competition?
Panasonic98 is offline
post #2 of 9 Old 08-01-2014, 03:48 AM
jdsmoothie's Avatar
Quoted: 14360 Post(s)
Liked: 6783
jdsmoothie is online now
post #3 of 9 Old 08-01-2014, 01:16 PM - Thread Starter
Liked: 0
So 80 watt per channel is enough power for these speakers?
post #4 of 9 Old 08-01-2014, 01:33 PM
jdsmoothie's Avatar
Liked: 6783
Yes. Even 50W would be more than enough. On average they use < 5W/CH.
post #5 of 9 Old 08-01-2014, 01:56 PM - Thread Starter
Liked: 0
So when Denon increases power output in higher models (i.e. x2000 - 95 watts, x3000 - 105 watts), it's just a marketing ploy?
post #6 of 9 Old 08-01-2014, 02:09 PM
jdsmoothie's Avatar
Liked: 6783
Ploy? Hardly. But there is very little difference between models based on their power differences. Don't shop based on power, rather shop based on the features a higher model offers.
post #7 of 9 Old 08-01-2014, 09:07 PM - Thread Starter
Liked: 0
I'm just concerned because I read a review for the Studiomonitor 350's on hometheaterreview.com and they said these speakers "ate up budget power sources." Here's a a snippet of the review-
"It should be noted again, however, that this design needs high quality power to really open up. There's a lot going on in that box, and it needs good stuff to move. Not necessarily Krell monoblocks, of course, but entry-level receivers and tiny, second zone amps need not apply. So, from a pure loudness standpoint, sure they'll play plenty loud, but be prepared to either pay for that privilege or start your amp on a death plunge (which, of course, will cost you anyhow)."
This is why I'm a little worried that this receiver might not be powerful enough to drive the speakers. The reviewer doesn't really specify what qualifies as a "budget receiver" though, so I'm not sure if the x1000 falls in that category. Here's a link to the review:
http://hometheaterreview.com/definit...kers-reviewed/
post #8 of 9 Old 08-01-2014, 09:23 PM - Thread Starter
Liked: 0
I'm also confused by what he means when he says "quality" power. Aren't watts just watts? Is the x1000 considered "high quality" power?
Sorry for all the questions, your help is very much appreciated.
post #9 of 9 Old 08-01-2014, 11:35 PM
jdsmoothie's Avatar
Liked: 6783
These are 8-ohm 90db bookshelf speakers which even the Def Tech specs say need only 20W to drive them.
