Denon AVR-591 - HFMI signals dropping out randomly - AVS Forum | Home Theater Discussions And Reviews
Old 08-01-2014, 04:04 AM - Thread Starter
cargle's Avatar
Liked: 0
Hi Everyone,
I have a Denon AV-591 Receiver
I have been having a problem for quite a while now where the HDMI signal drops out every so often (say 5-10 during a movie). As you can imagine it can be very annoying.. It drops out sound and screen goes blank.. it then detects the signal again a few seconds later and its back to normal.
I have my receiver connected to my computer however also a PS4 connected both using different HDMI cables and inputs on the back of the receiver. The same problem occurs on both signals (from computer and on PS4).
I have tried resetting the amp by holding the two < & > buttons, however this does not work either.
I am guessing that there is obviously a problem with the board or inputs on the amp, but thought I would just double check on here to see if there was anything else worth checking.
Thank you in advance
cargle is offline
Old 08-01-2014, 04:52 AM
jdsmoothie's Avatar
Quoted: 12182 Post(s)
Liked: 5549
Other than ensuring there is a secure connection at each end of the cables, you may want to upgrade to something more current.
http://www.amazon.com/Blue-Echo-lock...dmi+cable+lock
jdsmoothie is offline
