Does anybody know of a receiver with separate subwoofer control on the remote? - AVS Forum | Home Theater Discussions And Reviews
Old 08-01-2014, 04:48 AM - Thread Starter
Mastiff's Avatar
Quoted: 42 Post(s)
I need a receiver for a bathroom where both I and my wife/daugther listen to music, at separate times. We have quite violently different views on what's the right amount of bass, and I have system with all amps in a technical room and only speakers in the different rooms. So I have ceiling speakers and a passive sub in the bathroom. I would like to find an amp were I can adjust the subwoofer volume with the remote in the bathroom. I would prefer something that's 3-4 years old, so I won't have to fork out for a brand new receiver. It doesn't need HDMI or any other image functions, but I really want something that sounds good. By far the best would be something that can be split between pre and power amp (the jumpers in phono plugs variant), so I can use the same amp to drive the sub (by routing subwoofer out to one of the power amps that's not used). But it's not necessary, I do have an extra amp I can use for the sub if I have to. So does anybody have a suggestion for something that can work this way?
i7@ 3.6 - ATI 3870HD - Windows 7 64 bit - FFDShow with dScaler sharpen, AVISynth and Lancoz resize to BG808 with HD-144 lenses
Mastiff is offline
Old 08-01-2014, 02:05 PM
abatsky's Avatar
Check out NAD receivers.
abatsky is offline
Old 08-01-2014, 02:30 PM
Norde's Avatar
Quoted: 16 Post(s)
I know nothing about this product and it seems to be for automobiles, but would this be of any use?
If you can wire it up in your bathroom and attach it somewhere inconspicuous, for $12 it might be worth experimenting with
Proceed at your own risk.
http://www.sonicelectronix.com/item_...y-Scosche.html
Norde is offline
Old 08-01-2014, 02:34 PM
Liked: 4
Originally Posted by Mastiff View Post
... where both I and my wife/daugther listen to music, at separate times.
Is that even legal?
Tommy Lee 90120 is offline
Old 08-02-2014, 04:29 AM - Thread Starter
Mastiff's Avatar
Quoted: 42 Post(s)
Abatsky, thanks! That seems like the solution. The ironic thing is that I have the T750, which is one or two models below the T752, which has those functions. But I should be able to find a T752.
Nord, thanks, but everything goes on remote here, physical buttons is banned in my system!
Tommy Lee 90120, I live in Norway. Almost everything is legal here without asking Tipper Gore or the tea party first!
Mastiff is offline
