Windows USB connected to DAC. Can adjust tone, etc? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-03-2014, 03:30 AM - Thread Starter
Liked: 0
Question Windows USB connected to DAC. Can adjust tone, etc?
I'm planning on connecting a media centre Windows PC via USB to a DAC (possibly an Arcam rDAC).
I was wondering though, is it possible to adjust the bass/treble via windows? Also, even better could I hook up a software graphics Equaliser?
I know most people would frown upon this, but I can see that there might be a need to tweak the sound of certain genres of songs, and/or tweak the sound to suit my room!
Cheers
20_20000 is offline
post #2 of 3 Old 08-03-2014, 07:42 AM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
you should ask this at the HTPC topic. Short answer, yes you can, with the right software.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #3 of 3 Old 08-03-2014, 07:49 AM
Knucklehead90's Avatar
Quoted: 495 Post(s)
Liked: 423
I've never seen an equalizer utility within windows or Linux and I've been using both for almost 20 years. Since the DAC is connected via USB the windows/Linux operating systems should not have any control over the USB audio - which is what you want. The program you are using for playback is where you should look for equalizer control. I use FooBar2000 which has an equalizer built in with (IIRC) has about 15 channels of equalizer - I leave it flat - works for me. It decodes just about any format you might wish to play. Best thing is - its free and is IMO a very decent player. I've found substantial distortion when using an all around player like VLC Media Player and Windows Media Player. FooBar2000 only plays music - and does it well. I find the same distortion-free music using FooBar2000 whether its from USB (Emotiva XDA-1) or optical/coax from my Omega sound card.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
