Generic question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-03-2014, 05:23 PM - Thread Starter
nwf477's Avatar
Quoted: 226 Post(s)
Liked: 93
Generic question
I currently have an Integra DTR 5.5, it sounds great however it gets pretty hot then shuts down fairly quickly the few times I have cranked the volume.Now the question I am looking at getting another older rcvr somewhere between 85 and 110w. I am trying to keep things equal so I am basing my looking on distortion from 20hz to 20khz. with .08 or less thd. I have never heard any Harmon Kardon or Denon or Yamaha or Marantz, maybe would consider Pioneer Elite( read about all of these ). I am not looking for any specifics just what you think sounds the best. I am aware most of these use high current amps which improve the sound so if you were to pick a brand what would it be?
Thanks for the help.
nwf477 is offline
post #2 of 5 Old 08-03-2014, 05:29 PM
jdsmoothie's Avatar
Quoted: 12142 Post(s)
Liked: 5531
Better question is what is the impedance of the speakers you are trying to drive? If 4-ohm, you likely need an external amp with 200-300W.
jdsmoothie is offline
post #3 of 5 Old 08-03-2014, 05:51 PM
asarose247's Avatar
Quoted: 698 Post(s)
Liked: 454
google "coolerguys" for an easy to build 2 x 120mm fan cooling kit with AV equipment in mind,
also my shelves for most AV stuff are 3/4 ply with a cutout and stiffeners and then uses open mesh wire closet shelf, usually the 16" deep stuff to provide a totally open bottom to facilitate an "uncompromised" air flow.
just trying to help
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #4 of 5 Old 08-03-2014, 06:15 PM - Thread Starter
nwf477's Avatar
Quoted: 226 Post(s)
Liked: 93
Okay I was too vague my fault, the speakers I have are all book shelf 8ohm polarity, is correct for all 7. My entertainment center has been modified to allow better air flow to rcvr. I had to have the db setting set at -12db to get higher volume. If I play the movie THE WALL aprox. 3/4 volume the rcvr goes into self protect mode at lower volume does not break a sweat. I have read good and bad concerning Integra and Onkyo heat related problems and for what its worth I would rather have something not as prone to excessive heat as this. If it were not for this issue I would have no complaints. So yet again if you pro's out there if you were to purchase an older rcvr going with what I listed what would it be?
nwf477 is offline
post #5 of 5 Old 08-03-2014, 09:20 PM
Knucklehead90's Avatar
Quoted: 387 Post(s)
Liked: 334
I like Yamaha receivers. I've owned two in the past 3 years. I sold a Yamaha HTR-7065 to my nephew and missed it so bad I ended up with a 4 year old RX-V3900. It was their top of the line when it came onto the market. It has plenty of power and all the gadgets Yamaha could stuff into a 40 pound chassis. They can be had on ebay and Amazon. Used prices haven't dropped much apparently - Amazon used prices are right around $700 plus shipping. I've had more than a few Onkyo products but have had a few lemons so I steer clear of them.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
