To Amp or Not to Amp... - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By Craig Peer
  • 1 Post By DonH50
  • 2 Post By jdcrox
post #1 of 13 Old 08-05-2014, 02:15 PM - Thread Starter
Liked: 0
I'm just looking for some opinions on whether *you* would feel compelled to ad an amp to this setup, and if so, why?
AVR: Marantz SR7008 (auditioning in prep for SR7009)
Front R/L: Martin Logan Motion 40
C: Martin Logan Motion 30
Surround R/L: Martin Logan Motion 4
SW: Martin Logan Dynamo 700w
I picked up the 7008 (just set up yesterday) as a means to audition Marantz and Audyssey, and I plan to exchange it for the 7009, once it's released. The 7009 is spec'd for 4-16 Ohm impedance, so that concern with the MLs being 4 Ohm is eliminated, and I want the integrated WiFi & bluetooth, and MultEQ XT32.
I'm in a relatively small, odd shaped space. Essentially half of a 20' x 12' room (so 10' x 12') with 9' ceilings, open to a 2-level foyer at the rear. 9' viewing/listening distance.
Nothing is fully broken in yet (speaks have only been in for a couple weeks), but after running Audyssey yesterday... I'm impressed. But I'm really wondering how much I'm going to be leaving on the sidelines by driving everything with just the AVR? Not necessarily in volume but in quality. I like it loud, but I live in a townhouse, I did enough hearing damage when I was younger, and it sounded plenty loud in my limited listening yesterday. But I get the feeling the MLs are hungrier for considerably more than the 7008(9) can offer, and that I will be rewarded with even better SQ.
Usage is probably 70% HT to 30% 2/2.1 music.
I'm looking at Emo XPA-3/5 and Outlaw 7125, 7200 or 7500. I also have a feeler out to Classic Audio on some ATIs, and am open to recommendations in the affordable range. i.e., <2k.
TIA
briden is offline
post #2 of 13 Old 08-05-2014, 03:07 PM
DonH50's Avatar
Quoted: 1793 Post(s)
Liked: 1327
I don't see you needing an amp but whatever...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #3 of 13 Old 08-05-2014, 03:35 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Ohm's law guarantees that zero more power will be provided at sny given volume level. Speakers cannot smell the unused potential power and for any voltage gain, current will be defined precisely and invariably by the complex inpedance of the speakers in light of the frequency content of the source material. I cannot walk through walls or jump off a 20 story building without serious damage because of the physical laws of our universe. And an amp csnnot supply more power than (simplified) voltage and resistance allow. Its not a law like the speed limit its a law like gravity. If your current amp has inaudible distortion at your listening levels a more powerful amp will perhaps make distortion more inaudible if that means anything but it cannot ever supply more power at any given spl.
Iow at any given spl a more powerful amp is just as likely to float off into space as to provide more power to the speakers
JHAz is offline
post #4 of 13 Old 08-05-2014, 04:20 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3038 Post(s)
Liked: 2970
TIA
I had no problem driving MartinLogan Motion 40’s ( 2 ), one Motion 8 center speaker, Motion FX surrounds ( 4 ),and Motion LX16 wides ( 2 ), with a Denon 4520 . It's rated 150 watts / channel to the 7008's 125 watts / channel. But you are only driving 5 speakers! I was driving all 9. I only added an external amp when I got 2 Motion 4 height speakers, since the 4520 only powers 9 channels itself, and I wanted 11 channels.
briden likes this.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #5 of 13 Old 08-06-2014, 12:09 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
These forums are against dedicated power, to most a yamaha 361 will drive any speaker. Borrow a quality power amplifier and see for yourself.
fatbottom is offline
post #6 of 13 Old 08-06-2014, 12:16 AM
Sean Spamilton's Avatar
Quoted: 339 Post(s)
Liked: 364
You could always just do what I did and get a separate two channel amp to power your fronts - taking stress off your AVR, while using the receiver to power the rest of the channels. I have an Denon X4000 and at the time was running 7.2 (now running 9.2). Full disclosure, it made absolutely zero difference to the sound quality - it was good before, and remained good - but there was absolutely no difference in the sound. It would probably take a bit of stress of your Marantz that being said, not having to drive all the channels, but more likely then not you'd be fine anyways.
Sean Spamilton is online now
post #7 of 13 Old 08-06-2014, 09:06 AM
DonH50's Avatar
Liked: 1327
Most of us are against spending money on things that will not cause audible improvement. This is based upon technical knowledge and years (decades in many cases) of experience. And most of us with decades in this game have been through the upgrade games, from cables to amplifiers to shorting dust caps for our RCA connectors. You can discount our opinions and knowledge base, of course, and ultimately all that matters is if it sounds good to you. But, many of us have spent a lot of money on things that sounded good to us at the time, only to learn later we had fooled ourselves.
And there are a few times I have spent money on things that did make audible improvements, including more powerful amplifiers. I just don't see it in this case.
It really sucked when I was in college and learned my parents actually knew what they were talking about...
YMMV, FWIWFM, IMO, IME, etc. - Don
briden likes this.
post #8 of 13 Old 08-06-2014, 09:22 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 2970
That's what I'm doing too, to run 11 channels. It does sound different but only because I have 11 speakers running now vs 9 before. I never ran out of " head room " or had any distortion at sound levels up to the point where everyone told me " it's too loud - turn it down " without the external amp though! A lot will have to do with the size of your room of course. Your room is smaller than mine, which is 23' x 17'6" x 11' tall ( peaked ceiling ).
On the other hand, Emotiva has amps on sale often - doesn't cost too much to get a 150 watt / channel 2 channel amp like I did.
post #9 of 13 Old 08-06-2014, 09:39 AM - Thread Starter
Liked: 0
Thanks for the responses.
I came upon this article and associated thread today, and found them both to be enlightening.
briden is offline
post #10 of 13 Old 08-06-2014, 10:25 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Be careful in that forum, or you will be lusting for exotic power and speaker cables next!
Craig Peer and briden like this.
jdcrox is offline
post #11 of 13 Old 08-06-2014, 12:05 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Sometimes external amps sound worse, like when the external amp has hum you can't get rid of
"But this one goes up to 11"
MichaelJHuman is offline
post #12 of 13 Old 08-06-2014, 12:46 PM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
There's no difference between a 4 ohm receiver and an 8 ohm receiver. All receivers can play both. They can't play the 4 ohm speaker as loud before clipping.
KidHorn is offline
post #13 of 13 Old 08-06-2014, 12:56 PM
Quoted: 266 Post(s)
Liked: 148
There could be differences.
A receiver designed for 4 ohm operation could have better heat dissipation. Seems like a good idea, anyway. A receiver designed for 4 ohms could be optimized for lower impedance, especially the power supply. Look at Harmon Kardon in the past, somewhat low 8 ohm spec, but supposedly high current output.
I also wonder why you clip faster into a 4 ohm load? That could be generally true, but if the speakers in question have the same sensitivity, you put out 1/2 the voltage and twice the current into the 4 ohm speaker. You shouldn't clip due to hitting the voltage limit, unless drawing more current causes the power supply to collapse. I could be wrong on this.
