Costco two to choose from - AVS Forum | Home Theater Discussions And Reviews
Old 08-05-2014, 05:06 PM - Thread Starter
johnstac's Avatar
Which one would you choose?
Yamaha RX-V775BT or
Sony STR-DN840?
Just generally speaking if these are the only to you had a choice from and why?
johnstac is offline
Old 08-05-2014, 05:12 PM - Thread Starter
johnstac's Avatar
Yamaha RX-V775BT or
Sony STR-DN840?
Oh, the Yamaha is $489.99 and the Sony is $399.99
johnstac is offline
Old 08-05-2014, 05:21 PM
smurraybhm's Avatar
Quoted: 1474 Post(s)
Liked: 1765
Yamaha - easy choice if $ isn't an issue. At that price range you also could consider buying a Denon X2000 from an e retailer or Best Buy if you must go local. Denon is discounted right now as the new model is being rolled out.
smurraybhm is offline
Old 08-05-2014, 11:48 PM
Typ53b's Avatar
Go with the Sony-no-baloney...
http://www.soundandvision.com/conten...40-av-receiver
I have the 2014 model, the 1050. It's outstanding. At $400 for the 1040, it's a no-brainer. Absolute steal.
Typ53b is offline
Old 08-06-2014, 12:01 AM - Thread Starter
johnstac's Avatar
Well thanks. Completely undecided now. Both of you indicated it was an easy choice but both picked different rigs! Yikes... Guess you might make me do some homework for myself......
johnstac is offline
Old 08-06-2014, 08:16 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
I would go with the Sony. They have really stepped their game up with this model line. And from reading the reviews it shows.
Here is the Sound&Vision review of the Yamaha RX-V775. http://www.soundandvision.com/conten...wa-av-receiver
The Sony STR-DN1040 scored higher in ever categories. http://www.soundandvision.com/conten...40-av-receiver
crazyrob425 is offline
Old 11-29-2014, 01:25 PM
Dissident's Avatar
Liked: 0
The 840 is $100 now, so i just picked one up in store. FYI the Yamaha is $50 off now, too
Dissident is offline
Old 11-29-2014, 01:56 PM
Corey Fletcher's Avatar
Liked: 0
Go with the Sony. Great interface, awesome tech support, and easy to use.
Corey Fletcher is offline
Old 11-29-2014, 02:15 PM
delt31's Avatar
Quoted: 85 Post(s)
Newegg has the onkyo 626 for 299 with $25 off using visa checkout = 275 free shipping no tax. About 50 off of the costco sony option and just as good, if not better.
delt31 is offline
