surround sound receiver for background music - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-06-2014, 01:59 PM - Thread Starter
Liked: 0
Guys,
I have an old Sony 5.1 receiver and 4 x100w satellite speakers for it that I don't use. I've been thinking it might be nice to hook them up to the ceiling above my patio for outdoor background music. The space is covered and I'm in SoCal (no rain/weather to speak of) so I'm not concerned about the speakers being outside, and I have good access to run the wires where I need to. I'm just wondering though, will a surround sound speaker play music back from 4 speakers ok? I'd just want the same sound coming out of each speaker...not the receiver trying to push different sound elements through different speakers - how would I hook the speakers to the receiver to obtain that? My input source would likely be simple RCA inputs from a cable box (set to music channel) - or perhaps an optical (toslink) from the cable box...any advice?
thanks,
Matt
Matthew McDonald is offline
post #2 of 8 Old 08-06-2014, 02:40 PM
jdsmoothie's Avatar
Quoted: 12182 Post(s)
Liked: 5549
Most receivers have a Multi CH Stereo setting. Check the Owner's manual to confirm.
jdsmoothie is online now
post #3 of 8 Old 08-06-2014, 03:09 PM - Thread Starter
Liked: 0
thanks - it does - so on that setting, does the same sound get pushed to each speaker output? meaning I'd get the same sound from the center channel as from surround-left for example?
thanks,
Matt
post #4 of 8 Old 08-06-2014, 04:27 PM
jdsmoothie's Avatar
Liked: 5549
The same stereo content is played on each of the two L/R speakers and mixed to the center channel.
post #5 of 8 Old 08-06-2014, 04:56 PM - Thread Starter
Liked: 0
thanks!! OK - so if I were to hang 4 speakers in a line across a wall, in terms of creating good background music, do you think attaching them to just the left & right speaker outputs on the receiver is the best way to go? ie. hang them: Surr. Left, Surr Right, Front Left, Front Right?
Make sense?
post #6 of 8 Old 08-06-2014, 05:11 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
Yes....If you only have 4 speakers then don't connect the center channel.
Afro GT
afrogt is offline
post #7 of 8 Old 08-06-2014, 05:20 PM - Thread Starter
Liked: 0
great - thanks for the help guys!! As I'm looking at what I have - I'm probably going to have runs in the 40-60ft range. I only have 18gauge wire, which I know would be well sub-par typically for such long runs - but with the intension being just background music, do you think it'll sound ok? Also, I guess these satellite speakers would normally be paired with a sub - which won't be present - big issue?
-Matt
post #8 of 8 Old 08-06-2014, 05:36 PM
afrogt's Avatar
Liked: 758
You're gonna want thicker wire, probably 14ga as a minimum. See the chart in the link below.
http://www.roger-russell.com/wire/wire.htm
you can run your system w/o a sub, they'll probably sound a little thin tough, especially if they're satellite speakers.
Afro GT
afrogt is offline
