Pioneer VSX-1020-k -- flashing PQLS - AVS Forum | Home Theater Discussions And Reviews
Old 08-07-2014, 08:47 AM - Thread Starter
fox1541's Avatar
I recently started getting the flashing PQLS issue.
The receiver would turn off and the PQLS light is flashing. I've disconnected the speakers to try to find a culprit but it still shuts off.
The receiver is on a shelf with nothing blocking the vents and it's cool to the touch.
I've tried resetting it (Standby and Enter).. I've also tried changing the digital protection (or whatever it's called).
Any ideas? Is there a fuse or component that can be replaced? I have moderate soldering skills so that's an option.
thanks
fox1541 is offline
Old 08-07-2014, 11:05 AM
JChin's Avatar
Quoted: 194 Post(s)
Liked: 155
Originally Posted by fox1541 View Post
Any ideas?
Hi fox1541, don't know if this will help but try at your own risk. Press and hold the "Multi-Zone On/Off" and the "Tune Down" (or Preset Down) buttons for about 4-5 seconds and see if it power on.
JChin is offline
Old 08-07-2014, 02:24 PM - Thread Starter
fox1541's Avatar
What is this supposed to do? Does this perform some other type of reset?
fox1541 is offline
Old 08-07-2014, 04:07 PM
JChin's Avatar
Quoted: 194 Post(s)
Liked: 155
Performs a power amp reset.
JChin is offline
