Does this device exist? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-07-2014, 07:46 PM - Thread Starter
orcrone's Avatar
Quoted: 117 Post(s)
Liked: 24
I own a Yamaha RX-A2030 receiver with up to four zones. Zone 4 does not have any audio amplifiers; you just can use it to send the selected input source to a zone using an HDMI cable.In this zone I'd like to set up a 3.1 system for now, possibly expanding to 5.1 in the future. I realize I could purchase an inexpensive A/V receiver. But I don't need the source selection, Apple Airplay, Pandora, network capability, etc. I just need something with at least one HDMI input, one HDMI output and the ability to drive a 5.1 system.
Does this device exist or should I just look into inexpensive 5.1 home theater receivers?
orcrone is offline
post #2 of 5 Old 08-07-2014, 08:37 PM
grasshoppers's Avatar
Quoted: 812 Post(s)
Liked: 515
Inexpensive HDMI AVR is what you need.
I don't know of any other device that will
Do what you need.
grasshoppers is offline
post #3 of 5 Old 08-08-2014, 12:04 AM
jdsmoothie's Avatar
Quoted: 12354 Post(s)
Liked: 5643
You could just add a 5.1 sound bar w/sub as well.
http://www.definitivetech.com/products/sound-bars/
jdsmoothie is online now
post #4 of 5 Old 08-08-2014, 02:10 AM - Thread Starter
orcrone's Avatar
Quoted: 117 Post(s)
Liked: 24
Do what you need.
That's what I was thinking. I've found some refurbished ones very inexpensive. I guess there is no real advantage of what I'm looking for vs. an AVR.
orcrone is offline
post #5 of 5 Old 08-08-2014, 02:18 AM - Thread Starter
orcrone's Avatar
Quoted: 117 Post(s)
Liked: 24
When I purchased new LCR speakers (Paradigm Studio 100s and CC-690) for the home theater in the living room I was left with 3 in-wall Klipsch speakers, originally installed by the builder. I've moved two of them to either side of the TV in the master bedroom. Those two, along with the TV are run as zone 2 from the AVR. I figured if I added an AVR I could then install the third Klipsch above the TV (no room under it), as well as a Def Tech sub just sitting around.
orcrone is offline
