SP/DIF still OK ? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Kenwc
Old 08-08-2014, 08:44 AM - Thread Starter
Kenwc's Avatar
SP/DIF still OK ?
The Onkyo NR808 died last week, no sound, not that old. It's sitting on the workbench looking lonely.
Anyhow, an excuse to get new gear. One of the important features I want is HDMI passthrough. With this in mind, I ordered a Denon S900W. Hooked up the Cox Cable Contour box and the Samsung LN52B750 TV to the Denon via brand new RedMere HDMI cables. Well, the passthrough feature works about 90% of the time. When it fails, picture but no sound. Turn the Denon on and off, all is well. Unfortunately, 90% ain't 100% so the Denon gets returned and I get a Yamaha 677. Guess what, same problem. And back goes the Yamaha. Yes, I tried numerous settings on both receivers, even read the manuals. The fact that passthrough works most of the time indicates, at least to me, the settings are OK, the technology is flawed,
Now I'm thinking of going back to just using SP/DIF from the Contour, the Oppo 93, and the Xbox 360 into whatever receiver I get. Run the HDMI from the above directly into the TV bypassing the receiver completely.
So, finally the question. Do I lose any audio capabilities with SP/DIF verses HDMI audio?
And, maybe, I should try and get the Onkyo repaired ?
Thanks, Ken C
Kenwc is offline
Old 08-08-2014, 09:27 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
HDMI supports lossless audio. S/PDIF does not
"But this one goes up to 11"
MichaelJHuman is offline
Old 08-08-2014, 09:34 AM
KidHorn's Avatar
Quoted: 1380 Post(s)
Liked: 888
In theory HDMI can sound better. In practice, you probably won't be able to tell much difference.
It sounds like the problem may be with your cable box and/or TV. The handshaking seems flaky. Does it work all the time if you go straight from the cable box to the TV?
KidHorn is offline
Old 08-08-2014, 11:19 AM - Thread Starter
Kenwc's Avatar
100% with direct connection between the cable box and TV. I would agree it's a flaky handshake, curious only sound is disrupted. Ain't HDCP great !!
As I listen mostly to Bluray and cable TV, will I lose much not having lossless audio (FLAC) ?
Ken C
Kenwc is offline
Old 08-08-2014, 11:33 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Cable TV only does DD 5.1, so no issue there.
Lossless on Blu-ray is TrueHD and dts-MA. While S/PDIF doesn't support those codecs, the player will send high bitrate lossy versions that rival lossless in quality.
So, you likely won't lose any audio quality using S/PDIF instead of HDMI.
BIslander is offline
Old 08-08-2014, 11:49 AM
KidHorn's Avatar
Liked: 888
I used to have Comcast and the tech who set everything was not allowed to run hdmi through a receiver to the TV. Instead, he was required to run hdmi straight to the tv and toslink to the receiver. He said there were too many problems running hdmi through the receiver. Of course, he couldn't control what I did after he left, but it turns out he was right. Running hdmi through the receiver was unworkable. It wasn't that big a deal. It's just switching sources required pushing buttons on my TV remove and receiver instead of just the receiver. My PS3 ran HDMI through the receiver and worked fine. Fine, until my crappy Onkyo HDMI ports failed like they do with every Onkyo receiver.
Since then I switched to FIOS and everything works fine. Maybe switching providers or getting a new cable box is an option.
KidHorn is offline
Old 08-08-2014, 02:23 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
S/PDIF can handle lossless audio such as a PCM stream, but only in stereo..
But not a multi-channel stream such as a Dolby or DTS due to bandwidth issues..
Just my $0.03...
M Code is online now
Old 08-08-2014, 02:24 PM - Thread Starter
Kenwc's Avatar
Oh no, just switched from Directv to cable, don't want to go thru that again ! Plus,afaik, no other providers in this area.
Just sent an email to Onkyo, we'll see if they will help. The Onkyo will do everything I need If it isn't super expensive to repair maybe that's the way to go. Sure would like one of the new receivers though.
Looks like I can live with S/PDIF, that's what the Onkyo was using.
One wonders how the manufacturer's tested the HDMI passthrough function ? Reading the forums, seems to be a common problem with a bunch of receivers.
Regarding TrueHD and dts-MA, the Oppo 93 has two HDMI outputs, I'll send one directly to the TV for video and the second to the receiver for audio. Gets a bit complicated but should work. Why didn't I think of this before ? My head is about to explode !
Ken C
Kenwc is offline
Old 08-08-2014, 02:29 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
Ken C
Your mentioned HDMI problems with the cable box and Samsung display, is that neither are HDMI certified....
Without this pertinent certification the units have not passed the industry's component interoperability testing. Not having this certification it is a crap shoot whether or not things work rite through HDMI and CEC. Thats why in our AV install biz we will not sell/use/install any Samsung products including displays and blue-ray players.
Just my $0.03..
Old 08-08-2014, 02:48 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
No doubt the new cable box. Technically speaking the various providers provide signals that meet the same standards, and only the cable box knows anything about HDMI one way or the other.
arnyk is offline
Old 08-08-2014, 05:20 PM - Thread Starter
Kenwc's Avatar
Just my $0.03..
Well, that answers most of the questions abt the passthru problems. You would think if the manufacturer's are using the HDMI logo they should meet the standards. Oh well, I will stay with S/PDIF. Thanks for the info.
Ken C
Kenwc is offline
Old 08-11-2014, 09:31 AM - Thread Starter
Kenwc's Avatar
All of the above is moot as Onkyo will repair the unit under a one-time "extended" warranty. Good for them standing behind their products. A new receiver would be fun but saving $600+ is even better. And, hopefully in a few years, when I do upgrade, Onkyo will be in the mix.
Thanks, Ken C
matcartier likes this.
Kenwc is offline
Old 09-11-2014, 07:08 AM - Thread Starter
Kenwc's Avatar
Well, the saga has ended.
Onkyo did send a prepaid box to return the TX-NR808 for repair. The receiver was turned around in a little over 2 weeks, so far, so good.
After everything was connected, turned the receiver on and "ta da", we have sound ! Went through the setup, made sure all the assignable inputs were correct, did the Audyssey thing, checked the firmware, all looks ok.
Popped in a Bluray and realized something was not right. All I'm getting is 2 channel stereo. Not good. Checked a few things and discovered if the BD player's HDMI cable was disconnected from the Onkyo, the receiver would use the s/pdif connection. And, using this connection, the receiver produced Dolby D 5.1 audio.
Contacted Onkyo support via email and over the course of a week or so tried various combinations to no avail, HDMI audio yields 2 channel stereo no matter what.
I have three sources for digital audio, an Oppo 93 BD player, a Cox Contour cable box, and a Xbox 360. Dolby D via s/pdif, 2 channel stereo via HDMI in all cases.
So, yes, Onkyo fixed the no- sound problem, but (IMO) used a defective HDMI board.
Onkyo did not offer to correct this new problem.
Needless to say, Onkyo products will not be on my "buy" list.
And, we were SO close ...
Kenwc is offline
Old 09-11-2014, 07:13 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
2 channel PCM over SPDIF?
fatbottom is offline
