Av receiver hurts ears/need to pop my ears - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By audio4life
post #1 of 8 Old 08-10-2014, 09:44 AM - Thread Starter
Liked: 0
Purchased a Yamaha v775. Strange thing is it is somehow 'annoying' to my ears/brain although sounds perfectly fine. Feel like I need to 'pop' my ears while/after listening to it. Sound is through small speakers at low volumes. With other sources never a problem (so not the speakers)
Any ideas what could cause this? Serious answers only please.
This is true regardless if I go directly to speakers or if I go to my russound multiroom system and use the russound amp
Never experienced anything like this. Sounds perfectly fine and someone else said they noticed nothing annoying
SRBBRS is offline
post #2 of 8 Old 08-10-2014, 10:14 AM
audio4life's Avatar
Liked: 300
When you say, "with other sources never a problem" what are you referring too? Other sources means cd players, dvd/blu ray players, TV cable boxes, all which would connect with the Yamaha v775. But when you say other sources, you seem to mean other avrs or receivers that drive your speakers.
At any rate, you may be experiencing something called ear fatigue. This is commonly experienced when the sound is not balanced or flat across the audio spectrum, but is overly pronounced in the higher frequencies. It's hard to know at this point what you are hearing though.
The Yamaha is a good brand and that shouldn't be the issue, yet your are experiencing something. Did you run the Yamaha room correction system?
Five28 likes this.
audio4life is offline
post #3 of 8 Old 08-10-2014, 01:08 PM - Thread Starter
Liked: 0
Thanks for trying, the annoyance starts quick, not after an extended period.
By other sources I mean if I listen to USB music through my Denton mini system to my russound vs the Yamaha with the same USB to my russound through the same speakers/amp the Yamaha 'hurts' while the denon is pleasant
In this situation I am just using the line outs from the Yamaha, so I understand the room correction wouldn't apply (although I have the same problem when using the Yamaha amp to the speakers)
My logic tells me it is impossible, but there is an annoyance from the sound making it not useable
SRBBRS is offline
post #4 of 8 Old 08-10-2014, 05:31 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
What if you listen to the headphone output from the Yamaha? It's more or less the same signal going to the amp section, possibly even the identical signal perhaps with attenuation.
If it still happens to you there there might be something in the inherent signal causing this reaction
If not, I am not sure what would cause such a thing. Seems partly psychological, but that doesn't mean you are not reacting to something in the signal ( not suggesting it's all in your mind, in other words.)
This could also indicate some hearing issue. You might consider getting your hearing checked sometime if this continues.
"But this one goes up to 11"
MichaelJHuman is offline
post #5 of 8 Old 08-10-2014, 05:46 PM
audio4life's Avatar
Liked: 300
Yeah, I suspect that the hearing theory could be an issue here.
post #6 of 8 Old 08-10-2014, 07:19 PM
Worf's Avatar
Quoted: 562 Post(s)
Liked: 299
It's the secret mind control circuits that the Japanese embed in all their products. It's just not working on you.
But seriously, you really should get your hearing checked - and if you have some friends, have them check it out your system just in case you got a defective unit.
The fact you're feeling nauseous listening is troubling. Does it happen if you have the unit on but not playing anything?
Worf is online now
post #7 of 8 Old 08-10-2014, 11:50 PM
Roger Dressler's Avatar
Quoted: 1858 Post(s)
Liked: 986
Perhaps one of the speakers is connected opposite polarity. Check all the red/black connections, starting with L/R speakers.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #8 of 8 Old 04-09-2015, 04:11 AM
Liked: 0
Same here.....
Just bought a Yamaha VX777. Out of the box it sounded great but after 15 minutes some irritation in my ears occured.
I decided to buy a Marantz SR5009 and send the Yamaha back. Same thing. Although i must say dat the Marantz sounded in stereo a bit less itchy.
But in surround-mode the Marantz still did not sound pleasant to my ears.
It is a sound of pressure on/in the ear. A bit of noise/pressure in the ear is the result after 5-10 minutes of listening. The noise dissappears after a while (next morning). Decent volume (decent volume for watching a movie or listen to music without angry neighbours ;-p ).
I decided to hook op my old Arcam AVR200 and with this product I have no problems with my ears.
Before the Arcam I had a Onkyo receiver. Where I was the only one who had noisy ears after watching a movie. So i decided to switch over to Arcam.
So at this time I sort of disoriented of which receiver to buy. The Arcam AVR200 doesn't have hdmi support and is a bit to weak in power (watts).
A new Arcam holds a much higher price tag.
I use Piega's (S4) front en center in combination with Rel sub.
Problems occurs with sub on and off. In pure direct mode the pressure is less but still present.
I believe I have a sensitive ear for a dedicated range of the mid-high frequency's. So sensitive that it is a problem for me.
By the way with good old stereo amplifiers, i never had a problem with "sensitive" ears. That bothers me the most.
Why do I have no trouble with any stereo amplifier and do i have trouble with surround receivers. There must be an answer. Unfortunately I don't know what it is.
I'll keep searching for an receiver without problems for me. Any Suggestions?
Marty75 is offline
