Crown XLS Amp vs a used high-dollar 30 AMP beast? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 08-10-2014, 07:13 PM - Thread Starter
vince32837's Avatar
Quoted: 125 Post(s)
Liked: 111
Question Crown XLS Amp vs a used high-dollar 30 AMP beast?
I am going to be driving JTR 215 Full-Range speakers upfront (L-C-R). The speakers are 95 db sensitive/2000 watt RMS capable.
I have a read a lot of posts on the following amps
  • QSC PL 380
  • Crest Pro 9200
  • Lab Gruupen FP series(real no clone)
  • Crown XTI/IT series
Crown XLS
Q1) For 70 % movies and 30% music, can the highly efficient Crown XLS 1500/2500 drive the 215's to +10 dB over reference in a 30 x 20 ft room, or do I need to step up to one of the 20-30 amp power draw beast AMPS to get there?
I would most likely go used on the beast amps, due to cost.
If for my application the Crown XLS 2500 gets me +10 dB over reference with clear sound and the Crest Pro 9200 or LG 10000q gets me to +18 dB over reference...then the beast amps are not required...
Q2) Is there really magical sauce on the genuine LG FP series amps or they are equal with the other 30 amp beasts from 20-20 KHz?
Thanks in Advance-
Vince
vince32837 is offline
post #2 of 17 Old 08-10-2014, 07:35 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
Q1) Use this - http://myhometheater.homestead.com/splcalculator.html
Q2) No clue what you mean
Can't fathom trying to hit peaks of 115 dB, but 300 watts (XLS 1500 @ 8 ohms) is borderline according to the calculator even with those very efficient speakers. Why insist on +10 dB over reference?
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 17 Old 08-10-2014, 08:13 PM - Thread Starter
vince32837's Avatar
Quoted: 125 Post(s)
Liked: 111
Thanks for the calculator!
What I'm really after in Q2 is- will the Crown XLS 1500/2500 drive the 4-Ohm JTR's with authority, all the movie soundtrack peaks etc...will they be at the bottom of their gas tank?
if yes, then I will step up to the 20 TO 30 amp toaster oven beast amps, 1800-2500 watts in 4 ohms per channel measured...Crown XLS power ratings are peak true RMS is half that.
I thought ref level was 75-85 dB?
If the crowns due the job for me, I can go all new XLS amps for a 9.2 setup and get a warranty.
or
go used LG FP 10000q for LCR and Crown XLS 1500 for the 6 surrounds. (higher $$ route)
V
post #4 of 17 Old 08-10-2014, 09:04 PM
Quoted: 266 Post(s)
Liked: 151
Peak THX reference level is 105 dB per channel. Average is roughly 20 dB less or 85 dB
I never listen at reference level volume setting
If you just want peak reference level of 105 dB peak per channel any of the option you gave should manage with those speakers, especially as they are 4 ohm and those amps all put out a lot of 4 ohm power
Note that the LFE channel peak is 115 dB, which is why you probably want a competent sub if reference level is a goal
post #5 of 17 Old 08-11-2014, 12:57 AM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
The crown 1500 would power them clean and crazy loud. Your ears would give before the amp or speakers.
chalugadp is offline
post #6 of 17 Old 08-11-2014, 03:35 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Please define "Authority" in technical terms. DB SPL is preferred.
Got a SPL meter? Know what even 105 dB peaks sounds like?
If you don't have a SPL meter, here's a good cheap one - $30
http://www.ebay.com/itm/30-130dB-USB...-/251425940110
arnyk is offline
post #7 of 17 Old 08-11-2014, 04:06 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
A 200W (into 8ohm) let alone what it does into 4ohm will be more than you ever would need.
Something like Emotiva XPA-2 or ATI 1802.
fatbottom is offline
post #8 of 17 Old 08-11-2014, 04:41 AM
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
There is currently a special by guitar center and musician's friend on crown x series amps. These are re-badged crown xli amps. If you're curious about having enough power then grab one of these as they're an excellent deal at the moment. The x1000 seems to be sold out, but the x2000 and x4000 still seem to be in stock.
http://www.musiciansfriend.com/pro-a...350w-power-amp
As to whether you'll need it or notice a difference, that depends on several things not the least of which are your listening habits. The way I look at it is that a few hundred bucks seems like a down payment on satisfying your curiosity. Best of luck either way.
Just wanted to add that the very high power amps you mention are not the old style "toaster oven" amps if that's a concern for you. They're actually incredibly efficient. Especially the LG's.
cmryan821 is offline
post #9 of 17 Old 08-11-2014, 05:14 AM - Thread Starter
vince32837's Avatar
Quoted: 125 Post(s)
Liked: 111
I appreciate the inputs guys- The consensus here is Crown XLS 1500-2500 will get me not wanting more, in a 30 ft x 21 ft x 10 high dedicated room.
I'm building a new house, the builder wants to know in the next 2 weeks, "what power is required in the equipment room?" 15 amp/20 amp/30 amp dedicated outlets?
The crown xls series 15 to 20 amp dedicated should do...
For the beast pro amps, they all come with 30 amp plugs...
Dont need to waste installing that kind of firepower if it will never be utilized...
@ cmryan821- A crown test might be in order....
Thanks for the help!
Vince
post #10 of 17 Old 08-11-2014, 05:52 AM
smurraybhm's Avatar
Quoted: 1678 Post(s)
Liked: 2096
I would install a few extra dedicated circuits - 20 or 30 amps - just to have them available should you ever need them. A lot easier to do up front than later.
smurraybhm is offline
post #11 of 17 Old 08-11-2014, 06:17 AM
Nodscene's Avatar
Quoted: 134 Post(s)
For a home theatre room I'd definitely have a couple 20amp circuits at minimun.
Make something idiot-proof, and they will build a better idiot
Nodscene is offline
post #12 of 17 Old 08-11-2014, 06:26 AM
popalock's Avatar
Quoted: 1311 Post(s)
Liked: 1813
Vince
It will be much cheaper to future proof yourself now by installing a few extra dedicated lines as @smurraybhm suggested.
The only constant I have noticed here on AVS is change, so who knows what the future may bring your way that requires more juice.
I stand by the same philosophy when it comes to amp power... Enough power is enough until you want more. Excess power is excess until it becomes enough.
popalock is offline
post #13 of 17 Old 08-11-2014, 06:50 AM - Thread Starter
vince32837's Avatar
Quoted: 125 Post(s)
Liked: 111
The 3- JTR 215's supposed to have the bass output of one orbital shifter (OS). So I will start out without separate sub(s). But if bass is not enough, there is room for 1-2 Marty/Chaluga DIY boxes, or couple of S2's behind the false screen wall.
The room will be pretty, with surrounds in the columns, crown molding etc. so the only option for sub boxes is behind the stage..no matter what the USB microphone/REW S/W
says..
Like you guys say- cheaper to put in the power now, run one 30 amp dedicated, and a few 20-amp dediatced in the equip. room, and maybe two 20 amp dedicated behind the stage.
I guess I was reading too many 27.9 amp crown XTI, sine wave benchmark test posts, I needed you guys to give me a reality check...Of course the poster, was using the amp for a 1000 person music festival at the park. I ignored that part!
thanks Vince
post #14 of 17 Old 08-11-2014, 07:16 AM
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
Big +1. Right now is the time to future proofing and installing extra circuits if you're ever going to do it. It should only be a small additional cost from what I understand.
post #15 of 17 Old 08-16-2014, 08:38 AM
C O D Y's Avatar
Quoted: 67 Post(s)
Liked: 45
Would the Crown X4000 be a good amp to run 3 LCR JBL 3677's? I would also like to put 2 JBL 3635's (POWER CAPACITY 300 Watt) behind the screen, is the Crown X4000 a good amp for those too?
That sale link you posted seems like a great value for $300.
C O D Y is offline
post #16 of 17 Old 08-17-2014, 01:14 PM
DonH50's Avatar
Quoted: 2205 Post(s)
Liked: 1804
I would run two dedicated 20 A outlets plus some standard 15 A plugs for everything else. Also think about your lighting; I do not have track lighting and had a couple of duplex outlets wired so the bottom outlet runs through a switch by the door to turn on a light connected to the outlet.
If you are building I would seriously consider room isolation. Easy now, painful if not impractical later. I used Kinetics Noise Control's IsoMax clips to float walls and ceiling (floor is concrete basement). Double-thickness wall and ceiling panels glued together and all seams and other holes (e.g. electrical outlets, lights) sealed with caulk. I used rock wool insulation and isolated the media room from the house HVAC. I used a Fujitsu minisplit unit for the room HVAC but a number of manufacturers make similar units.
FWIWFM - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #17 of 17 Old 08-17-2014, 02:09 PM
C O D Y's Avatar
Quoted: 67 Post(s)
Liked: 45
That's good help. Thanks!
FWIWFM - Don
C O D Y is offline
