DENON AVR-4520CI 11.2 Surround Set Up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-12-2014, 10:48 PM - Thread Starter
iwanrs's Avatar
Quoted: 49 Post(s)
I am upgrading my Home Theater system from 1080p to 4K.
HT Room : 5m x 8m dedicated HT Room.
A/V Receiver : DENON AVR-4520CI. 11.2 surround capability.
Current Speakers : 7.2 system. 7 speakers and 2 subwoofers.
Projector : Sony VPL-VW1100ES 4K.
Screen : 150" EluneVision 4K Reference, 16:9, 2.40 gain.
I am thinking to upgrade the 7.2 speakers system to more speakers set up.
To have full 11.2 surround capability of Denon, I need to add another 4 speakers at front screen, namely 2 WIDE front speakers and 2 High front speakers.
For additional 2 Front WIDE Speakers: I cannot do this due to room width limitation.
For additional 2 Front HIGH Speakers: I can add this by hanging the speakers high up with the ceiling mount.
I need some advices:
Do the additional 2 Front HIGH Speakers (9.2 system) give a much better surround sound than my current 7.2 system ?
Worth to do the set up? For cost I do not need to buy extra speakers as I have 2 spare speakers available, only need to buy one pair of Speaker Mounting brackets (small investment).
All advices and recommendation are much appreciated.
iwanrs is offline
post #2 of 10 Old 08-12-2014, 11:56 PM
jdsmoothie's Avatar
Quoted: 15053 Post(s)
Liked: 7263
Depends on the movie sound track as to whether Front Height will provide any real benefit; however, you would also need an external 2CH amp to expand to 11.2.
Also note there is a dedicated thread for the Denon 4520CI ....
The **OFFICIAL** DENON AVR-4520CI thread
jdsmoothie is offline
post #3 of 10 Old 08-13-2014, 03:01 AM - Thread Starter
iwanrs's Avatar
Quoted: 49 Post(s)
I can only expand to 9.2, I can not do 11.2 because my HT room is not allow me to place another pair of Front Wide Speakers.
My screen is 150" big.
iwanrs is offline
post #4 of 10 Old 08-23-2014, 11:03 AM - Thread Starter
iwanrs's Avatar
Quoted: 49 Post(s)
No sound out of my 2 Front Height Speakers
I have install the extra 2 Front Height Speakers.
I have configured the 9.2 setting in Denon AVR-4520CI and tested all 9 speakers and 2 subwoofers fine, working well with test sound.
But there is NO sound out of that 2 Height Speakers !
I am using HTPC as media source. The control panel stated output sound is 7.2.
What am I missing here?
iwanrs is offline
post #5 of 10 Old 08-23-2014, 11:17 AM
jdsmoothie's Avatar
Liked: 7263
Are you using either DTS Neo:X or DSX as a surround mode?
post #6 of 10 Old 08-23-2014, 11:21 AM - Thread Starter
iwanrs's Avatar
Quoted: 49 Post(s)
Sorry to ask this D*** question:
My Denon front dispaly said: MULTI CH IN 7.1
How to set that DTSNeo . . . ?
iwanrs is offline
post #7 of 10 Old 08-23-2014, 11:24 AM
jdsmoothie's Avatar
Liked: 7263
That is the "input" signal. Press/hold the MOVIE button on the remote and select either DSX or DTS Neo:X.
post #8 of 10 Old 08-23-2014, 11:38 AM - Thread Starter
iwanrs's Avatar
Quoted: 49 Post(s)
Thanks Smoothie, you are my SAVIOR.
How can I missed that little green button !!!
Now, when I klick DSX and when DTS Neo:X ? (What are those terms mean anyway ?)
iwanrs is offline
post #9 of 10 Old 08-23-2014, 12:58 PM
jdsmoothie's Avatar
Liked: 7263
Just two different surround mode's ... one by Audyssey (DSX) and one by DTS. Try them both and use whichever one you prefer.
post #10 of 10 Old 08-23-2014, 05:58 PM - Thread Starter
iwanrs's Avatar
Quoted: 49 Post(s)
I try both.
If my source is 5.1 : Both working well, DSX and DTS Neo:X create sound of Front Height Speakers about the same as Standard Front Speakers.
If My source is 2.0 : DSX create (full) sound as Staandard Front speakers, on the other hand DTS Neo:X sounds totally difference (weird) it sound almost like surround speakers, only ambient sound not full content of Standard Height Speaker.
Question:
Will both accept Dolby and DTS surround, in standard and HD ?
iwanrs is offline
