Advice Please - Denon x3000 or x4000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-13-2014, 12:38 AM - Thread Starter
avkiller's Avatar
Quoted: 12 Post(s)
Hi,
I am just about to pull the trigger on a new Denon receiver and I can't decide whether to pay the extra $700 and go for the x4000 or save the money and get the x3000.
Here's my setup
Fronts 3 x Definitive Technology UIW RLSII behind acoustically transparent screen. http://www.definitivetech.com/products/uiw-rls-ii
Sourounds 2 x Definitive Technology UIW RSSII http://www.definitivetech.com/products/uiw-rss-ii
Subs 2 x SVS PB-2000
As far as i can see the main difference between the two receivers is slightly more wattage and the MultEQ XT Vs MultEQ XT32 although I could be wrong.
Any advice would be greatly appreciated.
avkiller is offline
post #2 of 4 Old 08-13-2014, 12:49 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
If there is a $700 difference in your country and you don't need any of the other features on the X4000, then the X3000 should serve you well.
jdsmoothie is offline
post #3 of 4 Old 08-13-2014, 01:14 AM - Thread Starter
avkiller's Avatar
Quoted: 12 Post(s)
Hi,
Yes its at least $700 difference here. I am just wondering if the x4000 would have significantly better audio quality or if its not going to be noticeable?
avkiller is offline
post #4 of 4 Old 08-13-2014, 01:19 AM
jdsmoothie's Avatar
Liked: 5502
It would be noticeable as the vast majority of former XT owners have noted going to X32; however, if you've never experienced Audyssey before, even XT on the X3000 will be an improvement.
