what should i do? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-14-2014, 02:05 PM - Thread Starter
aeliayousaf's Avatar
Quoted: 26 Post(s)
Liked: 4
what should i do?
I have an onkyo tx-nr809 which is 130W per channel at 0.08% distortion. then i have an Adcom GFA-545II which is 100wpc at 0.02% distortion. my question is would i get better sound if i use the Adcom as my power amp, or should i just leave them connected to the onkyo? My speakers are bi-amplified currently to the onkyo. thanks
aeliayousaf is offline
post #2 of 7 Old 08-14-2014, 02:09 PM
djp2k7's Avatar
Quoted: 138 Post(s)
Liked: 62
You should try both ways and see which sounds best! You may find it sounds better with the Adcom powering your fronts, especially if you're also running a center and surrounds.
djp2k7 is offline
post #3 of 7 Old 08-14-2014, 02:16 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 4
hmm yes, i might just have to experiment. i was just concerned about the wattage. 130w over 100w.
post #4 of 7 Old 08-14-2014, 05:21 PM
awblackmon's Avatar
Quoted: 51 Post(s)
Liked: 61
There is so little difference in wattage and distortion that it could well end up being a wash sound wise. I would try both ways and see what you like best. That is the fun of this hobby.
Mitsubishi 3800. Marantz 8802A Sound ably handled with Minimus 7 LCR speakers in a baffled wall behind AT screen. Surrounds are Paradigm in wall speakers. Overhead speakers for Atmos and DTS:X are minimus 77. DIY IB sub system. Two pairs of Dayton 15 inch in separate manifolds. Power amps are Harman Kardon Signature 2.1 doing basic 5 bed channels. Kenwood KM-X1 6 channel for L/R wide, overhead speakers and back surround. Kenwood Basic M1D doing Subwoofer work. Sound is 9.2.2.
awblackmon is offline
post #5 of 7 Old 08-14-2014, 11:38 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
No real difference in power if that's the whole story.
There is possibility the Adcom works better into lower impedance loads which could be of help ( even 8 ohm speakers dip down to lower impedances potentially.)
Yeah, I would say experimentation is your best option
That Adcom must almost be a classic by now
"But this one goes up to 11"
MichaelJHuman is offline
post #6 of 7 Old 08-15-2014, 10:50 AM - Thread Starter
Quoted: 26 Post(s)
Liked: 4
Yes its a classic now
So I tried both, and there was minimum difference. The Onkyo sounded a little louder, maybe by 2-5%. but overall hardly any difference. Only advantage at this point in using the Adcom would be less stress on the Onkyo front channel.
post #7 of 7 Old 08-19-2014, 01:31 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 4
I ended up going with the Onkyo amp. I also experimented with the bi-amping (which i had setup initially), and I noticed no difference there too (bi-amping vs. regular). I ended up using the 7 channels and added surround rears and front high speakers, and what a big difference that makes. Adding more speakers IMO was a better way to go.
