Needing help with a reciever - AVS Forum | Home Theater Discussions And Reviews
Old 08-15-2014, 12:34 PM - Thread Starter
Liked: 0
I have a Sony HTDDW660 and it was given to me everything works fine except I just recently ordered an optical cable, Now it wont show DTS audio it only says Dolby Pro Logic. I have the optical cable hooked to my tv and the other end into the receiver mentioned above my tv is set on PCM for the optical out and when I change that to Dolby Digital it still does not phase it. The device that I'm trying to get the DTS from is a Samsung Bdc5500 Blu ray player and it has all of the DTS decoding and everything in it. I also forgot to mention I do not have rear speakers I am working on getting some So I have the subwoofer its not powered aand two fronts and a center but I would think the DTS would still kick on. It shows the logo painted onto the receiver so it is DTS capable. I have it on AFD Auto and that is supposed to Decode the DTS but like I said all i get is Dolby Pro Logic and Dolby Pro Logic 2. Is there anything I can do to fix this?
Nick Mattingly is offline
Old 08-15-2014, 01:16 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 756
That's because your TV cannot bitstream a DTS signal. It converts it to 2 channel PCM.
Connect the optical output of your blu ray player directly to the Sony system and you'll be able to get DTS audio.
Afro GT
afrogt is offline
Old 08-15-2014, 05:13 PM - Thread Starter
Liked: 0
That worked thanks a lot. I thought a tv could transmit dts audio but I guess not. It explains now why my friends 5.1 wouldn't work coming from his tv. Thanks again I will be back if I need anything else.
