Toslink Switchers or other options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-17-2014, 06:18 PM - Thread Starter
konigsberg7's Avatar
Quoted: 90 Post(s)
I want a setup where I have 1 TV (22 inches so no HDMI ARC) and like 4 inputs to audio and video. I have an HDMI switcher for the video but I want special audio through an amplifier.
So I buy an amp, now all these devices such as the PS4 and Xbox360 all have outputs for toslink, but I cant really find a toslink switcher thats more than 3.
I havent invested in such a setup but does anyone have any good ideas where I could basically switch between the 4 audio and visually with speakers and headphones and possible even 5 and then 6 switches for the future? Again the only restriction is that I cant use HDMI ARC because the TV I have for this setup is http://www.samsung.com/us/video/tvs/UN22F5000AFXZA -- 22 inches
konigsberg7 is offline
post #2 of 14 Old 08-17-2014, 06:56 PM
jdsmoothie's Avatar
Quoted: 12186 Post(s)
Liked: 5554
Simply purchase 1 more optical switch with 1 of them feeding into the other which then gives you 5 optical inputs.
jdsmoothie is online now
post #3 of 14 Old 08-17-2014, 07:40 PM - Thread Starter
Quoted: 90 Post(s)
Is this how you would do it? I still haven't bought anything else except that TV.
I'm just wondering someone who know's a lot about AV would do such a setup
post #4 of 14 Old 08-17-2014, 08:17 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi konigsberg7, want to understand your setup.
You have:
- 22" TV with 2 HDMI input which doesn't support ARC (Audio Return Channel) and no Optical Out
- HDMI switch (maybe a 4x1 or 4x2 ?)
- amp (what model ?)
You want:
- video out to 22" TV
- audio through speakers connected to the amp
- audio through optical for headphones (because headphones has as optical input ?)
JChin is offline
post #5 of 14 Old 08-17-2014, 09:03 PM - Thread Starter
Quoted: 90 Post(s)
You have:
You want:
I just have a 22 inch TV and it does have optical output, Jesus I totally forgot about that, way more possibilties open (in my head)
Still open to other setups.
Again the only thing is that I have this TV: http://www.samsung.com/us/video/tvs/...-0813-11000279 :
Specs are on the site
post #6 of 14 Old 08-17-2014, 11:55 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
I don’t know what you’re trying do.
JChin is offline
post #7 of 14 Old 08-19-2014, 04:22 PM - Thread Starter
Quoted: 90 Post(s)
I want that TV connected to (one TV to 5 devices) 5 devices which do have toslink digital optical output (Gaming Consoles and a PC). which will let me use some sort of small speakers and headphones. --- All connected to one TV. SO I would need an AV switch system between the 5
So I'm open to suggestions on
Speakers (I have Sennheiser HD650 headphones)
an Amp if required
a way to switch the audio between devices
and whatever else you can think of in a setup like this because I don't know much about this stuff. It doesn't have to use digital. I'd use an AV reciever but it doesn't have HDMI ARC (the TV)
Also all devices have HDMI outputs too
post #8 of 14 Old 08-19-2014, 04:37 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
I'd use an AV reciever but it doesn't have HDMI ARC (the TV). Also all devices have HDMI outputs too
Why don't you just buy a AV Receiver and use that as your audio and video switcher? Connect all your devices to the receiver since they're HDMI and connect a single cable to the TV.
Why do you feel your need ARC? You don't, you're not sending anything from the TV to the receiver.
Afro GT
afrogt is online now
post #9 of 14 Old 08-19-2014, 04:44 PM
smcmillan2's Avatar
Quoted: 379 Post(s)
Liked: 223
Well, then you're all set. HDMI from devices into the switcher, HDMI out of the switcher to the TV, TOSLINK from TV to receiver.
For recommendations on receivers/amps/speakers you'll need to provide more information - Budget, room size at a minimum I would think. If you go with a receiver (with enough HDMI inputs) you can eliminate the HDMI switcher and TOSLINK.
EDIT: What afrogt said...
Last edited by smcmillan2; 08-19-2014 at 04:50 PM. Reason: Because Afro GT beat me to it... ;-)
smcmillan2 is offline
post #10 of 14 Old 08-19-2014, 04:45 PM
afrogt's Avatar
Liked: 758
This receiver has 7 HDMI inputs. Should cover all your needs very well.
http://www.ebay.com/itm/TASCAM-PAR10...item1e9086f564
Afro GT
post #11 of 14 Old 08-19-2014, 07:28 PM - Thread Starter
Quoted: 90 Post(s)
Oh, wow. Thanks
post #12 of 14 Old 08-20-2014, 01:55 AM - Thread Starter
Quoted: 90 Post(s)
lol, one more thing. I'm pretty sure the answer is yes... but If I got a monitor instead of a TV -- the monitor has HDMI but no speakers or digital output... The HDMI will still work with the receiver and output audio through the receiver, correct?
post #13 of 14 Old 08-20-2014, 02:08 AM
jdsmoothie's Avatar
Liked: 5554
Correct as long as the monitor can be set to a standard TV resolution.
post #14 of 14 Old 08-20-2014, 03:25 AM - Thread Starter
Quoted: 90 Post(s)
What do you mean? Meaning that the monitor must support resolutions such as 1920x1080 (1080p) 1280x720 (720p) etc? What monitors wouldn't now a days?
