Simple question about HDMI - AVS Forum | Home Theater Discussions And Reviews
Old 08-17-2014, 08:14 PM - Thread Starter
Liked: 0
Question Simple question about HDMI
I have a 2007 Sony receiver with a small number of HDMI inputs/outputs (2/1). On this receiver, if you put HDMI into the receiver and out to the TV, the sound only goes to the TV. I have a component system and like to listen to the TV shows on my 5.1 surround setup. Sometimes on the TV speakers, at night when I don't want to keep my family awake. Anyway, with the old receiver I connected digital coax and optical from my cable box and blue-ray player so I could get the sound over my amp.
Having blue-ray player troubles, and got a new one. It doesn't have any audio output
except thru the HDMI. So, I can't do that bypass now. Here's the basic question: is this behavior of my 2007 receiver normal? If I buy a new receiver, can I put an HDMI into it from my other components, and get sound out of both the tv speakers and the system speakers? Or do I have to go find a new Blue-ray player with more outputs?
melott is offline
Old 08-17-2014, 08:53 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Back in 2007 it was not uncommon for inexpensive receivers to just be HDMI switchers, requiring a separate audio connection to get sound to the speakers. These days, all AVRs can process sound from HDMI inputs. So,a new AVR would seem to be in order. Or, return the new player and get one with a coax or optical output.
BIslander is offline
Old 08-18-2014, 06:36 AM - Thread Starter
Liked: 0
Question receiver recommendation?
My 2007 receiver is a Sony for which I paid $400. It is 5.1 and I have been extremely happy with it. I have a lot of inputs (Blue-ray, VCR, casette, cable box) and a 5.1
speaker setup with auxillary in another room. Sometimes I use the TV speakers.
Would another Sony be a good choice in this sort of price range? The TV is a Panasonic.
melott is offline
Old 08-18-2014, 01:47 PM - Thread Starter
Liked: 0
Question HDMI output
If the HDMI output is sent to the TV, does this mean that the receiver itself will not play the sound on speakers that are connected to it...on a modern receiver? I have been doing some looking around, and it appears this may be true, at least for Sony.
melott is offline
Old 08-18-2014, 02:11 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
For best audio quality don't send audio through the tv. Connect all sources to the receiver with only 1 hdmi cable from receiver to tv. Audio can be passed both directions along that last hdmi cable using arc (audio return channel). Audio can be passed through the receiver to tv with receiver on or off (standby passthrough). Get a new receiver. Sony isn't known as the best brand around these days. Expand your research. Normally pick either tv or stereo speakers.
kikkenit2 is offline
Old 08-18-2014, 06:46 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Or, get a player with a coax or optical output for audio. That would be a cheaper way to go.
Old 08-18-2014, 06:47 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
You have to send audio to the receiver somehow. Yours doesn't process audio over HDMI, so you need some other sort of connection.
Old 08-18-2014, 07:42 PM - Thread Starter
Liked: 0
Arrow
I understand now. Thanks to everyone. I am getting another blu-ray player as the expeditious cheap solution. But I have to look beyond this. OK, so Sony isn't the good mid-level stuff now. What are the good brands for the $300 to $700 price range? Need lots of inputs--including a phono jack!!
melott is offline
Old 08-19-2014, 03:06 AM
Luke M's Avatar
Quoted: 280 Post(s)
Liked: 79
There's a small chance that your TV can pass through Dolby Digital and DTS from HDMI to optical out. In that case, all you would need to do is connect an optical cable and configure the TV to pass the raw audio. Most TVs can't do this, however - you only get PCM (two channels) out, except when using the TV tuner.
Luke M is offline
Old 08-19-2014, 06:04 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Panasonic TVs do not pass through encoded audio from HDMI inputs. At least, I've never seen one that does.
