Help needed with receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-19-2014, 08:37 AM - Thread Starter
Liked: 0
So i just purchased a set of JBL 180 floorstanding speakers, i am clueless on this kind of this so i am going to ask here. what would be an ideal receiver for me??
Info: Budget 150-250$(trying to get by cheaper with some good quailty
Plans: will be used for home stereo and when i watch TV/Games. Mainly a home stereo though. Plan to later on add a 10 inch woofer and maybe a center speaker.
Room setup: irrelevant as my job requires me to move every 6 months so it will change quite often
any advice would be awesome you guys, i got these speakers on sale for 89$ from 350 each so i figured its about time i put me together something that sounds better then a ipod dock which is what i am using at the moment
Poostar is offline
post #2 of 13 Old 08-19-2014, 09:49 AM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 969
Do you need/want networking on your AV receiver? Might as well get one with Airplay so you can stream iTunes to your system.
http://www.accessories4less.com/make...airplay/1.html
Afro GT
afrogt is offline
post #3 of 13 Old 08-19-2014, 11:01 AM
kikkenit2's Avatar
Quoted: 823 Post(s)
Liked: 305
I see so many denon failure/problem threads around here lately. D&M cheaped them out.
They just don't last. I would go with Yamaha. Lot less failures/bugs etc.
http://www.accessories4less.com/make...rx-v475/1.html
kikkenit2 is offline
post #4 of 13 Old 08-19-2014, 11:30 AM - Thread Starter
Liked: 0
http://www.accessories4less.com/make...-v475/1.htmley
link does not work for me. In order to power what i am wanting what are the specs i should be looking at? and is denon really that bad? like i said i do not know about this stuff and really need to be told what to buy. Just want to make sure it is going to power the speakers i have being shipped to the house now.
Poostar is offline
post #5 of 13 Old 08-19-2014, 11:39 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4781
Has an extra ey at the end of the link, try this http://www.accessories4less.com/make...rx-v475/1.html
What speakers did you get? Their sensitivity rating will tell you how loud you might expect to drive them. That the receiver can power them well enough isn't much of a worry unless you have particularly hard to drive speakers at high spl's. Just select the features you need/warranty/return policy/price that works for you....
lovinthehd is offline
post #6 of 13 Old 08-19-2014, 12:02 PM - Thread Starter
Liked: 0
Link the the speakers i got. http://www.jbl.com/estore/jbl/us/pro...atId=cat140013
I bought the same model on newegg and got them for 89$ a piece.
Poostar is offline
post #7 of 13 Old 08-19-2014, 01:50 PM
kikkenit2's Avatar
Quoted: 823 Post(s)
Liked: 305
Sorry about that. Fixed. Here is the spec sheet on your towers. 8 ohm, 89db, 90 watts. Piece of cake.
http://www.ehifi.com.au/downloads/fi...20EU)_834e.pdf
As far as denon do a search of this whole receiver forum just today through last sunday. Just use the word denon.
A bunch of posts and new threads about problems. About 10 on sunday alone.
post #8 of 13 Old 08-19-2014, 04:03 PM
lovinthehd's Avatar
Liked: 4781
Is Denon now the favorite consumer electronic brand to have failures? Anecdotal evidence mostly compared to numbers sold IMHO. I bought an Onkyo when it was advised as highly probable to fail....no issues. Get an extended warranty might be a good way to go with an avr. There are only so many actual factories making them for the brands....
post #9 of 13 Old 08-19-2014, 04:36 PM
kikkenit2's Avatar
Quoted: 823 Post(s)
Liked: 305
I have only worked in one factory and that was 40 years ago. We made several brands of french frys. They all came from the same pile of potatoes. They didn't all taste the same. And they were not all made the same way.
In any receiver factory the quality of tooling/chassis design and the individual part quality can vary. Bad parts/chassis design are ticking time bombs. Some are doa. Some fail soon and some just after warranty runs out. And some will last a long time. It is all about percentages. Sunday was network card issue after hdmi issue etc. with several posts of I have the exact same problem. On several different models and all within 2 to 3 years old. About the time Bain Capital bought D&M. I heard rumors they cut the team and lower spec'd the parts. It may be finally showing up. Sunday was brutal and a few more today. More than normal. Do a denon search for aug 17.
post #10 of 13 Old 08-23-2014, 08:31 PM - Thread Starter
Liked: 0
going to go with the yamaha receiver. listed here. http://www.accessories4less.com/make...rx-v475/1.html
My question is this this same receiver (listed below) from newegg for cheaper or do my eyes deceive me?
http://www.newegg.com/Product/Produc...140824032715:s
Going to pull the trigger on one of these as soon as i get the ok from one of you guys. any benefits that one retailer offers that i dont see?
Poostar is offline
post #11 of 13 Old 08-23-2014, 08:57 PM
lovinthehd's Avatar
Liked: 4781
Slight difference in model designation (4066 vs 4066BL but BL probably is just a reference to the basic color). I dunno. I'd go with whoever made any necessary returns/dissatisfaction easier to deal with....with price as a consideration as well of course. YMMV
post #12 of 13 Old 08-23-2014, 09:18 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Reallly?
Really?
I guess my Denon AVR which is now about 18 months old and holding strong didn't get the memo.
I have one of those but I replaced with a Denon to get the features I wanted.
What is being recommended is such good equipment that Yamaha is seriously talking about quitting the AVR market, Here's your chance to have an orphan.
Looking at the Yammie sitting in my store room, its replacment model is far lighter but still based on the same technology, so now who is it that is cheapening out?
arnyk is offline
post #13 of 13 Old 08-24-2014, 07:55 AM
kikkenit2's Avatar
Quoted: 823 Post(s)
Liked: 305
Same model. Bl means black. Less reliability doesn't mean total failure. It means more failures.
There are a lot more posts around here for denon failures than yamaha. Even Onkyo doesn't
have every receiver made break early. Just more than anybody else. Yamaha is known for
lighter weight/smaller power supplys.
They may pack it up and leave. There isn't much profit to be had making receivers. As far
as profit d&m has none while Yamaha has some. I only see the failures on the 12, 13 and lower
x series. The high end stuff is still rock solid. My 4311 still works perfectly.
