How will an upgrade from my Yamaha RX-Z7 to and Anthem AVM 50 3d effect the sound? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By grasshoppers
post #1 of 12 Old 08-27-2014, 10:36 AM - Thread Starter
Halbrium's Avatar
Quoted: 22 Post(s)
I currently have B&W CM9s and CM5s in 5.1 and a 220 watt per channel 5 channel Anthem amp. How will an upgrade from my Yamaha RX-Z7 to and Anthem AVM 50 3d effect the sound?
I used to power my CM9s from my receiver, however the upgrade to the Anthem amp seemed to product a huge change in sound in terms of sound stage and general clarity. The fox fanfare blow me away every time I listen to it.
I want to see if I can take my system to the next level and I wonder if a prepro would be the way to do that?
Halbrium is offline
post #2 of 12 Old 08-27-2014, 03:47 PM - Thread Starter
Halbrium's Avatar
Quoted: 22 Post(s)
Please help! I have read a bunch of reviews and articles but I can't find a specific explanation for the difference.
Halbrium is offline
post #3 of 12 Old 08-27-2014, 04:11 PM
grasshoppers's Avatar
Quoted: 861 Post(s)
Liked: 562
The Anthem has ARC (Anthem Room Correction)
Which is In my humble opinion is light years
Ahead of the Yamaha's "YPAO" correction.
Frankly, I don't see a down side..my opinion as
An Anthem MRX AVR owner.
grasshoppers is offline
post #4 of 12 Old 08-27-2014, 08:17 PM - Thread Starter
Halbrium's Avatar
Quoted: 22 Post(s)
Is there a difference in sound without the room correction?
Halbrium is offline
post #5 of 12 Old 08-27-2014, 09:48 PM
Quoted: 861 Post(s)
Liked: 562
Should be about the same, but the Anthem
Is probably one of the most highly regarded
Pre/pro out there.
Remember 75% of what we hear is the speakers and
how they react to the room where we listen.
25% is the electronics.
You've got the good speakers already, what about the
Room?
This is the advantage of ARC.
jproy13 likes this.
post #6 of 12 Old 08-28-2014, 07:56 AM - Thread Starter
Halbrium's Avatar
Quoted: 22 Post(s)
What about http://us.marantz.com/us/Products/Pa...oductId=AV8801
It's half the price and all the reviews I have read praise it's room correction.
Halbrium is offline
post #7 of 12 Old 08-28-2014, 03:00 PM
Quoted: 861 Post(s)
Liked: 562
That is also a very good choice. The Audyssey in
The Marantz is the best consumer version available
At the moment. The reviews have been very solid
For xt32 with sub EQ.
What is it you are trying to accomplish??
post #8 of 12 Old 08-28-2014, 03:03 PM - Thread Starter
Halbrium's Avatar
Quoted: 22 Post(s)
My use is 95% home theater, some music (pop, rock, folk) but not a ton.
I want the dialogue to sound more natural (less amplified if that makes sense) and to be clearer. In general I just want it to sound better. I think the CM9's are good speakers and adding the Anthem amp seemed to make a huge difference in terms of clarity and low end. I'm trying to find a way to get another jump, and I figure using a 2009 mid-level Yamaha receiver isn't close to optimal.
Halbrium is offline
post #9 of 12 Old 08-28-2014, 03:11 PM
Quoted: 861 Post(s)
Liked: 562
Ok, the Anthem AVM has a ton of high end video features
On it. If you are going to be focusing on sound then the
Marantz will be a better value!!
PS-"low end" equals a great sub or two. Your speakers aren't
Going to kick butt on the low end! You don't mention what
Subwoofer(s) you use??
post #10 of 12 Old 08-28-2014, 05:54 PM - Thread Starter
Halbrium's Avatar
Quoted: 22 Post(s)
Pulled the trigger on the Marantz! Thanks for your help. I use B&W ASW 12 CM Sub.
Halbrium is offline
post #11 of 12 Old 08-28-2014, 06:24 PM
Quoted: 861 Post(s)
Liked: 562
Good to hear!
Any reason why you picked a B&W sub?
For the money you paid for that sub you
Could have got a couple (2) of killer ID subs
(Internet Direct) that will crush the B&W.
(Unless you are not in the States)
I sense an upgrade opportunity!
post #12 of 12 Old 08-28-2014, 06:31 PM
Quoted: 861 Post(s)
Liked: 562
Please do a follow up post on what you think
About your new Pre-amp!
