How to connect PC, Sony DAV-S550 and 5.1 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-28-2014, 11:40 AM - Thread Starter
Liked: 0
Hi Everyone,
Recently my Samsung AV receiver died so I had to dig out my old Sony DAV-S550 to replace it. I'm trying to connect it to PC but it's becoming a real nightmare.
At the moment I don't want to spend money on new AV receiver, so if it's possible I would like to use that Sony one, but I'm not sure if it's possible at all.
On PC side I have 3 different sound cards:
1. Built-in motherboard with 3 jacks
2. Creative Labs Sound Blaster Audigy 2 ZS with jacks, Firewire (I don't know what for) and digital coaxial (which AV receiver doesn't have)
3. Terratec Aureon 5.1 with jacks and 2 Toslink connectors.
Sony DAV-S550 has plenty of RCA jacks and Toslink connector.
https://www.flickr.com/photos/127305043@N02/
I tried to connect it with a Toslink cable but for some reason it doesn't work.
The only way that I managed to connect speakers through this AV receiver was by 1 jack - 2 RCA cable, but only 2 speakers with a subwoofer are working.
Does anyone know if it's possible and how to connect PC to this AV Receiver so all five speakers are working?
la chupacabra is offline
post #2 of 4 Old 08-28-2014, 12:01 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Change the sound mode on your Sony from Stereo to something else like Dolby Pro Logic II or Cinema Studio EX.
Page 48-50 explains how to change your sound fields.
pdf.crse.com/manuals/4241065131.pdf
Afro GT
afrogt is offline
post #3 of 4 Old 08-29-2014, 09:22 AM - Thread Starter
Liked: 0
Unfortunately I lost the remote control. Is there a way to make it work? I thought that it should work straight after connecting Toslink cable and choosing the right source on AV receiver.
If not with a Toslink cable, can I connect it with analogue cables so all 5 speakers and sub woofer would work?
post #4 of 4 Old 08-29-2014, 11:08 AM - Thread Starter
Liked: 0
I installed new software from Terratec website and the sound is working now from Toslink connection, but only on 2 speakers. When I run a settings program there seems to be no option to set it up for 5.1 and it's impossible to set it up under Windows Control Panel (Configure option is greyed out). Any suggestions? Is it possoble that this sound card only support 2 speakers on Toslink cable?
https://www.flickr.com/photos/127305...2/15051473016/
