Upgrade or NOT? from Denon 4311ci to Yamaha RX-A2020 ??? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Selden Ball
Old 08-29-2014, 10:02 AM - Thread Starter
Pianist718's Avatar
Quoted: 134 Post(s)
Hi guys,
I currently own Denon 4311ci and it's a very nice receiver. I did however once tested it vs the Yamaha RX-A2020.
Yamaha was very impressive with the clarity of sound (a bit more detail was heard with higher frequencies) and LFE was amazing (better than 4311ci) but I still kept Denon 4311 as it did better with regular TV from cable sound.
I got thinking that maybe the reason why Denon was not giving such detail as Yamaha is because of my poor room acoustics and maybe Denon's Audyssey room correction software on purpose made sound a bit less bright to compensate??? Could that be? Should I try turning off the Audessey and test those movies again? But then all other setting (LFE volume) won't be accurate.
Any thoughts?
thank you
Sharp LC-80LE650U 80-inch, Denon AVR 4311ci, Ascend Sierra-1 NrT, Ascend HTM-200 (surrounds), Rythmik F12, WD TV Live Media Player, Samsung BD ES6000, Denon DVD-2910 & Sony BDP-S370 SACD/DVDa, Monster HTS 5100 MKI, Monster Z2 Biwire, Logitech Harmony One, Sennheiser HD600, Schiit Modi/Vali
Pianist718 is offline
Old 08-29-2014, 11:34 AM
Selden Ball's Avatar
Quoted: 3055 Post(s)
Liked: 1494
Audyssey has two major settings that Denon calls "Audyssey Reference" and "Flat". Reference includes a high-frequency rolloff to compensate for a high-frequency boost often included in theatrical mixes. Flat might be more appropriate for you.
Often small changes in the way the calibration was done can cause unexpected differences in how the result sounds. You might want to try running the calibration again, following the guidelines in the Audyssey 101 document. See "Official" Audyssey thread (FAQ in post #51779)
Bill Mac likes this.
Selden
Selden Ball is offline
Old 08-29-2014, 12:08 PM
Bill Mac's Avatar
Quoted: 1265 Post(s)
Liked: 1442
Selden,
Excellent advice . Specifically the suggestion to recalibrate following the guidelines in the provided link. I prefer the "Flat" setting over the "Reference" setting.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
Old 08-29-2014, 12:38 PM - Thread Starter
Pianist718's Avatar
Quoted: 134 Post(s)
Originally Posted by Bill Mac View Post
Selden,
Bill
My Denon 4311 only offers FLAT, Manual, or L/R Off
Old 08-29-2014, 12:52 PM
Liked: 1494
I think you're overlooking the plain "Audyssey" setting. The suffix "Reference" was added for later models, presumably to reduce this kind of confusion In particular, see page 89 of the 4311's manual. "Audyssey" includes the hf rolloff, "Auidyssey Flat" does not. See the attached screengrab.
Selden
Old 08-29-2014, 02:10 PM - Thread Starter
Pianist718's Avatar
Quoted: 134 Post(s)
So suggestion is to try FLAT option as well as Turning it completely OFF.
right?
Old 08-29-2014, 02:37 PM
Liked: 1494
Right. And/or run another calibration.
Selden
Old 08-29-2014, 07:32 PM - Thread Starter
Pianist718's Avatar
Quoted: 134 Post(s)
Selden,
Bill
Hmm ... just checked and I do not have an option FLAT. Only Manual, OFF and l/r off or Audeyssey
Either way ... I tried checking sound with Audessey OFF and bass was a bit lighter than when I have it turned on. Highs are a bit more pronounced but not by much.
Old 08-29-2014, 08:16 PM
fordf250's Avatar
Hello Pianist718-the progression in Audio adjust for Audyssey should be "Audyssey"; the next step being "Audyssey Flat". Try going to "Auto Setup", Parameter check; scroll down to equalization; and there should be two curves-one for "Audyssey", and one for "Audyssey Flat".
fordf250 is offline
Old 08-30-2014, 05:58 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
The use of the word "Reference" has just started with the release of the new 2014 D&M models.
jdsmoothie is offline
Old 08-30-2014, 07:14 AM
Bill Mac's Avatar
Liked: 1442
I have the 4311 and just checked the Audyssey options using the Audyssey button on the 4311's remote. The options are "Audyssey", "Audyssey Flat" and "Off". You could try using the remote button instead of going into the 4311's menu. If you are not seeing the "Flat" setting there must be some setting in the menu causing the "Flat" setting option not to show.
Bill
Bill Mac is offline
Old 08-30-2014, 01:17 PM - Thread Starter
Pianist718's Avatar
Quoted: 134 Post(s)
Bill
Yea in Menu I actually turned it off. It;'s back ON again. Will do some testing over the weekend.
