Step down transformer for Denon AVR-1513 - AVS Forum | Home Theater Discussions And Reviews
Old 08-31-2014, 07:59 AM - Thread Starter
Liked: 0
I purchased a Denon AVR-1513 from the US and I want to use it in India. The power requirements are 110V at 60 Hz. What type of step down transformer should I use with this AV receiver? What should be the power capacity of the transformer? I was suggested to purchase a 1KVA capacity transformer. Does that sound right?
Where can I purchase the transformer in Bangalore? I saw a Maxine 1KVA transformer on amazon.in for 4.5K. Is that too expensive?
Once I decide to buy the transformer how can I test it before connecting the receiver, to make sure that my AV Receiver won't get damaged?
Aaron Dsouza is offline
Old 08-12-2016, 09:39 PM
Liked: 0
Hi Aaron,
Did you purchase "Maxine 1KVA transformer"? If so, Is is it performing good.
vengalamp is offline
