Marantz sr5009 - AVS Forum | Home Theater Discussions And Reviews
Old 08-31-2014, 07:37 PM - Thread Starter
m4vrick's Avatar
Marantz sr5009
Hello,
I just purchased Marantz sr5009 receiver, but it seems to be freezing up once in a while and when that happens the controller or buttons on receiver don't work. Only way to get receiver to work again is by unplugging it and then going through the setup menu.
Im running latest firmware. I haven't don't any micro processor reset procedures yet, but I just wanted to know if anyone else experience same issue or have any ideas that I can try to resolve it. Freezes happen randomly. 1st time when i just tried to turn off the receiver and 2nd time was tv was just on, then screen went black with no signal, it came back for a sec, but then turned off and froze. Had to unplug it.
THanks
m4vrick is offline
Old 09-01-2014, 12:07 AM
Quoted: 12 Post(s)
Liked: 1
That's frustrating , I've had the sr5009 for about a month now and have not experienced that problem, fingers crossed. There's a few threads here on AVS about other Marantz models freezing up , they may be worth looking into ...
v_man is offline
Old 09-01-2014, 03:55 AM
jdsmoothie's Avatar
Quoted: 12307 Post(s)
Liked: 5612
Exchange it for a replacement.
jdsmoothie is offline
Old 09-03-2014, 07:55 PM
bgmspd's Avatar
Liked: 0
I've had mine for about a week and have the same issue. I will sometimes have the HDMI pass through for video only with no sound and other times no video signal at all no matter what component I switch it to. My system did seem to just start with this issue after it asked to upgrade firmware and I allowed it during standby. Next time I turned it on no signal to TV from any source. I'll be calling Marantz tomorrow.
bgmspd is offline
Old 09-03-2014, 08:11 PM
Quoted: 12 Post(s)
Liked: 1
Let us now what they say bgmspd , I also did a firmware update on standby , and I had one brief issue where nothing worked , but it turned out the firmware download just wasn't finished , and as soon as it did finish , the receiver worked fine .
v_man is offline
Old 10-04-2014, 12:55 PM
nosey313's Avatar
SR5009 Setup without HDMI
Couldn't find an official 5009 thread so thought I should just post here.
I finally upgraded my dead 5003 and just got around to attempting to set it up. First question I have: How do I access setup without HDMI? The genius who owned this house before me decided to finish the basement without access to the ceiling. He ran component cables to the projector box but not HDMI. No easy way to run it up there either.
I unplugged everything from the 5003 and reattached it to the corresponding inputs and outputs on the 5009. Turned on the unit and got a picture (more on audio in a minute) from the BR and DTV boxes. However, the unit display reads Setup on TV and I can't do anything with the remote. Does this need to plugged into HDMI? If so I don't know what I'm going to do about it.
Second question is the audio. I reattached all speaker wires the same way but no sound is coming out. Does this have something to do with the setup?
Any help is appreciated. Mods, if this is in the wrong thread please move. Thanks!
TWC FREE FOR YEARS
nosey313 is offline
Old 10-04-2014, 01:19 PM
jdsmoothie's Avatar
Liked: 5612
The GUI OSD only displays over HDMI so may want to go out and purchase a small 12" HDMI TV for setup only. Another option is using a laptop/tablet and entering the unit's IP address into a web browser (see Web Control p. 136 Owner's Manual).
Old 10-04-2014, 01:21 PM
nosey313's Avatar
Ah, thanks. Do you think that the audio issue is related to setup? I took out all speak wires except one to check and still no audio.
TWC FREE FOR YEARS
nosey313 is offline
Old 10-04-2014, 01:26 PM
jdsmoothie's Avatar
Liked: 5612
The FL/FR speakers should be enabled by default. So you should hear audio.
Old 10-04-2014, 01:27 PM
nosey313's Avatar
FYI... I did have a smaller TV in storage and hooked it up. Setup appears!
Crud, well I don't know why speakers wouldn't be working. They worked fine before I swapped out the unit. Stumped.
TWC FREE FOR YEARS
nosey313 is offline
Old 10-04-2014, 03:36 PM
jdsmoothie's Avatar
Liked: 5612
What sources have you tried? Have you tried the TUNER? Try unplugging the power cable on the AVR for 10 minutes (soft reset).
Old 10-13-2014, 07:29 AM
Liked: 0
I just purchased a sr5009 myself and have had the lock up or freezing issue twice. It has the latest Firmware and unplugging it seems to be the only thing to do to reset it. Have you found an answer to fix the issue yet? Thanks
moxieavs is offline
Old 10-13-2014, 07:45 AM
Liked: 0
moxieavs is offline
Old 10-21-2014, 04:01 PM
Liked: 0
I have the exact same problem with my SR5009..
If i use my PS4 via HDMI, the freezing accurs.. But if i use it with the optical cabel it wont freeze.
But my PC that i only can use via the HDMI port, it freezes alot, sometimes 4 times in one hour, and other times 1 in 3.
Erik Forslund is offline
Old 10-25-2014, 12:23 PM
Liked: 0
Other than doing the factory reset, does anyone have any advice about resolving this? I have this freeze issue regularly when my son plays Xbox One through HDMI. My unit is only a couple of weeks old.
OFK1961 is offline
Old 10-30-2014, 09:58 PM
cpercival's Avatar
Quoted: 20 Post(s)
Mine did it for the first time tonight. Ps4 via hdmi. Still no resolution?
cpercival is offline
Old 10-31-2014, 06:15 AM
jdsmoothie's Avatar
Liked: 5612
Try doing a microprocessor reset (p. 233 Owner's manual) about 4-5 times in a row and if still no joy, exchange it if still within the exchange period.
Old 10-31-2014, 11:14 PM
tennyis's Avatar
any update on the freezing issues? I'm debating getting one of these, but also have a line on a used arcam avr400 for basically the same price. WOuld I be better off with the Arcam? I know it does not have near the features being older.. but the new fancy AVR's with all these features seem to all have issues.
tennyis is offline
Old 11-01-2014, 03:39 AM
jdsmoothie's Avatar
Liked: 5612
Keep in mind that generally only people with issues will post here ... you're not hearing from the many thousands of owners who have no issues at all.
Old 11-14-2014, 10:22 AM
Liked: 0
ok so now my marantz SR 5009 has been on service 3 weeks now.. And the authorized service firm cant say when it will be done, they cant figure it out.
Old 11-14-2014, 01:26 PM
jdsmoothie's Avatar
Liked: 5612
If it goes beyond 30 days, they should at least offer a refurbished unit to replace it.
Old 12-18-2014, 08:19 PM
solodogg's Avatar
i've had my SR5009 for about a month now, and it has frozen up twice on me, only able to be remedied by power cycling the unit. I sure didn't expect to spend $900 on a receiver, and start having issues this soon. At least the Yamaha lasted me a few years before it started giving me trouble.
Can anyone make a decent receiver in this price range anymore?
solodogg is offline
Old 01-01-2015, 08:10 AM
zafirex's Avatar
Liked: 0
Known issue
Marantz customer service says freezing is a known issue and they are working on getting it solved.
Mine freezes after 20+ minutes of internet music streaming. The music usually keeps playing.
Power cycling (unplug, wait 30 seconds, replug) will allow the unit to work again in the meantime.
zafirex is offline
Old 01-19-2015, 09:14 AM
Quoted: 119 Post(s)
Liked: 7
my new SR5009 after the recent firmware update, gets itself repeatedly on & off after 1.5-2 hours of play. I checked my speakers wire and it all looks OK. After i give the AVR rest for sometime, it is operating normally. But again after 2 hours of usage, it keeps on & off repeatedly. Not sure where lies the issue.
murlidher is online now
Old 01-20-2015, 06:30 AM
EVfan's Avatar
Sorry for everyone's troubles. Got mine yesterday, it required a firmware update, so I updated firmware. Played music for 7 hours straight, then watched Ender's Game after. Worked like a champ, I'm very impressed my unit.
JVC RS46 with Elite Starling Tab-tensioned 100" screen
Samsung 63" PNC 7000
Marantz SR5009
Kef Q500 front L&R
Kef Q200c Center
Kef HTS 3001 Rears
EVfan is offline
Old 01-22-2015, 08:38 AM
Liked: 0
Anyone here Had the SR5009 and Switched to the SR6009, i'm debating which one to get. Thanks in advance
mike
bigmix007 is offline
Old 01-22-2015, 08:47 AM
jdsmoothie's Avatar
Liked: 5612
Upgrade only for more features offered on the SR6009 as sound quality should be the same.
Old 01-22-2015, 09:07 AM
Liked: 0
Thanks the price different was only going to be $135 more and was debating if that was worth the upgrade as I don't need zone 2 however 10 more watts I thought would make a difference.
Old 01-22-2015, 09:08 AM
jdsmoothie's Avatar
Liked: 5612
Nope ... it won't. You would need to add a 200W+ external amp for there to be any difference.
Old 01-22-2015, 09:16 AM
Quoted: 119 Post(s)
Liked: 7
Is the feature of front width feature and DTS neo x isn't worth to upgrade to 6009…?
HT - Marantz SR6009 -> Dali Zensor 7 + Zensor Vokal + Zensor 3 (surround) + JBL Control 1 (FH) + SVS PB1000
