How to do passthrough mode on AVR1710 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jdsmoothie
post #1 of 13 Old 09-01-2014, 04:05 PM - Thread Starter
cdoublejj's Avatar
Quoted: 20 Post(s)
Ho do i shut off the surround sound and do just the TV speakers? it says it has pass through on the box.
EDIT: What if i hook my tuner box and HTPC up via optical?
cdoublejj is offline
post #2 of 13 Old 09-01-2014, 05:32 PM
jdsmoothie's Avatar
Quoted: 12144 Post(s)
Liked: 5532
If you are trying to pass the HDMI video/audio through the AVR when it is in Standby mode, simply set HDMI Control to ON and set the Standby Source to whatever HDMI input you want to pass through. If on the other hand you want to pass the video/audio through while the AVR is ON, then set the HDMI Audio Out setting to TV.
cdoublejj likes this.
jdsmoothie is offline
post #3 of 13 Old 09-01-2014, 06:17 PM - Thread Starter
cdoublejj's Avatar
Quoted: 20 Post(s)
Now the question is how do i do that?
Also on a side note, after second look pass through is not listed on the box, maybe the people saying it doesn't have it are right?
post #4 of 13 Old 09-01-2014, 06:36 PM
jdsmoothie's Avatar
Liked: 5532
Never mind. You're referring to the HK 1710.
post #5 of 13 Old 09-01-2014, 09:47 PM - Thread Starter
cdoublejj's Avatar
Quoted: 20 Post(s)
I'm screwed huh? what about optical out? isn't optical out on a device on all the time, so long as it is enabled? then couldn't the HK1710 function for sound only leaving my other devices hooked to the TV with audio as they would be sans surround sound, thus allowing me to turn the HK1710 off and on at my will?
post #6 of 13 Old 09-02-2014, 04:57 AM
jdsmoothie's Avatar
Liked: 5532
Yes. That work around would solve your problem as well .... source (HDMI) to TV with source (optical) to the 1710.
post #7 of 13 Old 09-02-2014, 04:43 PM - Thread Starter
cdoublejj's Avatar
Quoted: 20 Post(s)
This makes me happy. I tried HDMI on my HTPC and it looked garbage so i can keep the VGA cable.
post #8 of 13 Old 09-03-2014, 06:54 PM - Thread Starter
cdoublejj's Avatar
Quoted: 20 Post(s)
is it true optical will only give me stereo?
post #9 of 13 Old 09-03-2014, 10:59 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
From what source?
From a cable/sat box to the receiver you'll get Dolby Digital 5.1 just like you would from HDMI.
The best a cable/sat box can do is Dolby Digital 5.1 and optical supports that.
From your PC? It depends.
Afro GT
afrogt is offline
post #10 of 13 Old 09-04-2014, 11:42 AM - Thread Starter
cdoublejj's Avatar
Quoted: 20 Post(s)
Originally Posted by afrogt View Post
From what source?
http://www.overclock.net/t/1510685/w...#post_22795704
I'm having just one heck of time with this and usually electronics and computers are my forte. Okay so 5.1 can work but, as it is now even with the cable box set to matrix i don't get sound from the rear speakers watching TV that is supposedly broadcasting in 5.1 grant it i'm hooked up via HDMI since the optical cables have not arrived yet.
post #11 of 13 Old 09-04-2014, 03:53 PM
afrogt's Avatar
Liked: 757
Do you have your speakers connected to the surrounds or surrounds back terminals? The surrounds are for 5.1 and surrounds backs for 7.1.
Your cable box should have an option to bitstream Dolby Digital. Is that turned on? It should not be on Matrix.
Afro GT
afrogt is offline
post #12 of 13 Old 09-05-2014, 08:43 PM - Thread Starter
cdoublejj's Avatar
Quoted: 20 Post(s)
Mono > Stereo > Matrix
HTPC
AMD AM2+ Gigabyte GA-MA785GPM-UD2H/US2H
4gb DDR2 800
Regor 240 @ 3.6
GT640 2GB
Cable Box
DCX3400-M
Receiver
AVR1710
TV
Sony Bravia form around 2006, 720P
http://www.harmankardon.com/estore/h...R%201710_HK_US
http://www.engadget.com/products/motorola/dcx3400/
http://www.gigabyte.com/products/pro...px?pid=3139#ov
http://www.gigabyte.com/products/pro...px?pid=3447#ov
EDIT: Maybe optical would bypass that all together.
post #13 of 13 Old 09-06-2014, 08:19 PM - Thread Starter
cdoublejj's Avatar
Quoted: 20 Post(s)
also in it's internal settings it has an "HDMI Link" setting. When i set it to audo form the TV box it says Dolby but ,the cable box doesn't have Dolby in the audio settings.
