Help with DTS-MA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 09-03-2014, 09:10 PM - Thread Starter
Liked: 0
Help with DTS-MA
Hi all,
I have a panasonic SC-XH185 DVD Home theatre system, which doesn't support DTS or any higher audio format. I get the Dolby 5.1 perfectly across the speakers.
Sometime ago I got the Panasonic BDT230 3D Blu-ray player and hooked up its Audio-out to the Home theatre system via Optical cable (Toslink). Now I get the Dolby audio nicely from the Blu-rays as well.
However since the majority of Blu-rays have DTS-MA, I don't get the surround effect as I get from the Dolby audio, presumably because the Home theatre doesn't support it.
How do I go about fixing this? Can I connect my Home theatre speakers to a different amplifier receiver? (And remove the home theatre receiver altogether?)
This is the layout of devices I have set up now,
randy077 is offline
post #2 of 23 Old 09-03-2014, 09:17 PM
NorthSky's Avatar
Quoted: 6841 Post(s)
Liked: 3416
Go inside the Blu-ray disc audio menu and select the appropriate audio soundtrack.
Or press the Audio button on your remote till you get the proper sound.
*** Or! On your Blu-ray player Setup Menu, for the Audio Out, select PCM as the Output.
~ Bob
"And it stoned me to my soul"
- Van Morrison
NorthSky is offline
post #3 of 23 Old 09-03-2014, 09:24 PM
Kini62's Avatar
Quoted: 1253 Post(s)
Liked: 1155
You can't get the lossless dts-ma or Dolby true hd over optical. Hdmi only.
Kini62 is online now
post #4 of 23 Old 09-03-2014, 09:32 PM - Thread Starter
Liked: 0
Thanks Kini62!
I get the surround effects even when I play Dolby TrueHD. (through optical) It's only the DTS-MA that doesn't quite have the same surround effect. I have switched between them and tested. Therefore I guess the Home theatre doesn't support the format, and I get a flat sound.
Does it mean if I use a HDMI cable to get audio from the Blu-ray player to the Home theater, I may get the full surround effect?
randy077 is offline
post #5 of 23 Old 09-03-2014, 10:17 PM
afrogt's Avatar
Quoted: 905 Post(s)
Liked: 689
Buy a new AV Receiver that can handle TrueHD and DTS-MA. Even the $110 Denon 1513 would be better than what you have.
http://www.accessories4less.com/make...d-ready/1.html
Afro GT
afrogt is online now
post #6 of 23 Old 09-04-2014, 03:12 AM - Thread Starter
Liked: 0
Hi afrogt,
Can a new receiver accommodate the speaker system of the existing Home theatre? The pins are as shown in the image below. Or can they be converted somehow?
randy077 is offline
post #7 of 23 Old 09-04-2014, 03:41 AM
jdsmoothie's Avatar
Quoted: 11007 Post(s)
Liked: 5094
Originally Posted by randy077 View Post
Thanks Kini62!
Actually no you don't. What the BDP is playing is the standard DD 5.1 track. As kini62 noted, DD TrueHD cannot pass over optical.
Hi afrogt,
A HTIB is designed to work as a whole. Just sell it and buy an AVR with a separate 5.1 speaker setup like the one below.
http://www.monoprice.com/Product?seq...FSdk7AodbWAAXQ
jdsmoothie is online now
post #8 of 23 Old 09-04-2014, 03:46 AM - Thread Starter
Liked: 0
Hi jdsmoothie,
If I do that, am I still in trouble if the BDPlayer has only 1 HDMI output? (because it's connected to the TV)
Or do I connect the BDP and AVR, and then connect AVR to TV?
randy077 is offline
post #9 of 23 Old 09-04-2014, 04:58 PM
Alan P's Avatar
Quoted: 4325 Post(s)
Liked: 3007
Alan P is offline
post #10 of 23 Old 09-04-2014, 05:02 PM
berstuck's Avatar
Quoted: 66 Post(s)
Liked: 52
What he's trying to say is, start over from scratch. This time do it correctly.
berstuck is offline
post #11 of 23 Old 09-04-2014, 05:07 PM
NorthSky's Avatar
Liked: 3416
He still can get the core audio (DD+) from Dolby TrueHD. ...From the digital Optical connection.
As for dts, is there a DD 5.1 audio track with Blu-ray's encoded DTS-HD MA soundtracks? ...Again, only the dts core audio. ...And very unfortunately no go with his receiver.
That reminds me of my old Yamaha 2092 receiver (DD only, no dts decoder).
* Solution: Upgrading? ...Your money, your call, I'd say go for it. ...Borrow money from your girlfriend.
~ Bob
- Van Morrison
NorthSky is offline
post #12 of 23 Old 09-04-2014, 07:06 PM
jdsmoothie's Avatar
Liked: 5094
Well ... the core DD but not DD+ as DD+ is an HD codec and requires HDMI.
post #13 of 23 Old 09-04-2014, 08:50 PM - Thread Starter
Liked: 0
Thanks a lot guys.
randy077 is offline
post #14 of 23 Old 09-04-2014, 10:43 PM
NorthSky's Avatar
Liked: 3416
You sure? ...DD @ 640 kbps?
~ Bob
- Van Morrison
NorthSky is offline
post #15 of 23 Old 09-04-2014, 10:44 PM
NorthSky's Avatar
Liked: 3416
Thanks a lot guys.
What are you going to do Randy?
~ Bob
- Van Morrison
NorthSky is offline
post #16 of 23 Old 09-04-2014, 10:50 PM
jdsmoothie's Avatar
Liked: 5094
DD max bit rate on a BD is 640kbps ==> optical or digital coax
DD+ max bit rate on BD is 6.1Mbps ==> HDMI
post #17 of 23 Old 09-04-2014, 10:54 PM - Thread Starter
Liked: 0
I've checked out some receivers which could do the job, but not in the budget right now...So I guess gotta hold on for some time.
randy077 is offline
post #18 of 23 Old 09-05-2014, 12:05 AM
NorthSky's Avatar
Liked: 3416
Thank you sir.
Ok Randy.
_______
<<<>>> If someone is reading this thread, and has a spare receiver that he can give to Randy;
that would be a generous gesture, and I'm sure Randy can take care of the shipping.
Thank you for your cooperation.
~ Bob
- Van Morrison
NorthSky is offline
post #19 of 23 Old 09-05-2014, 03:29 PM
Gurba's Avatar
Quoted: 385 Post(s)
Liked: 186
It shouldn't be a problem to use the speakers you have With a New receiver. Just cut the plugs and strip the wires.
Gurba is offline
post #20 of 23 Old 09-05-2014, 07:10 PM
BIslander's Avatar
Quoted: 245 Post(s)
Liked: 190
Most HTIB speakers should not be used with a regular receiver. HTIBs usually have 3 ohm speakers and will cause most receivers to work too hard. Most receivers want 6-8 ohm speakers. Plus, HTIBs usually have passive rather than powered subs. So, check the specs of your Panasonic speakers to determine whether they are suitable for re-use.
As for your current situation, the BD player will send TrueHD tracks as DD 5.1 at the maximum 640k bitrate and will rival lossless in quality. Since your system can't decode DTS, you have to set the player to PCM, which means you will only get stereo since optical doesn't support multichannel PCM. You can apply a mode such as PLII in the sound system to generate multichannel audio. But, it won't be discrete 5.1.
BIslander is offline
post #21 of 23 Old 09-05-2014, 10:57 PM
NorthSky's Avatar
Liked: 3416
Right on BIslander.
~ Bob
- Van Morrison
NorthSky is offline
post #22 of 23 Old 09-06-2014, 12:31 AM
Liked: 0
lacelogide is offline
post #23 of 23 Old 09-06-2014, 01:27 AM
NorthSky's Avatar
Liked: 3416
Which HTIB system do you have?
~ Bob
- Van Morrison
NorthSky is offline
