Would the new Marantz SR 7009 be a significant upgrade over SR7005? - AVS Forum
post #1 of 4 Old 09-04-2014, 02:52 AM - Thread Starter
keenly's Avatar
I currently have the Marantz SR7005 powering PMC DB 1i's(5).
I was looking to upgrade within the next few months. I like the fact the SR7009 can take DSD direct and is wireless, but would it be a significant upgrade in sound? I use NO EQ and never will. I just play auto for Blu Rays, SACDS, DVD Audios and music via USB. The other receiver I am thinking of purchasing is the Yamah 3030, again can take DSD and great with movies.
Any thoughts/ comparisons?
cheers
keenly is offline
post #2 of 4 Old 09-04-2014, 04:19 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 1003 Post(s)
Liked: 1502
If you use the Audyssey MultEQ XT32 it would, yes.
"JD" –
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AV Gear
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Def Tech, Atlantic Tech, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #3 of 4 Old 09-04-2014, 10:35 AM - Thread Starter
keenly's Avatar
I would not use the EQ.
keenly is offline
post #4 of 4 Old 09-04-2014, 11:46 AM
noah katz's Avatar
Quoted: 201 Post(s)
Liked: 153
Then IMO the only reason to upgrade would be for Atmos.
Noah
noah katz is offline
User Tag List
