Yamaha RX-V475 Network Problems - AVS | Home Theater Discussions And Reviews
post #1 of 2 Old 10-10-2014, 12:13 PM - Thread Starter
alexkilo's Avatar
Hello,
I recently purchased the RX-V475 and just today got myself a Netgear WNCE2001 WiFi Adapter so that I could enjoy the network features of the new receiver. After getting the adapter set up on my network, I plugged it into the Ethernet port of the receiver, and have had NO success getting it to work at all. When trying to update the firmware from the receiver's OS, using Network Update, the thing restarts, shortly says "Verifying" and then stops saying "Device Error", at which point I have to hard shut down the system. I have tried using a freshly FAT32 formatted USB flash drive with only the .bin file from Yamaha's download site and the receiver will not recognize any content from the drive. Any ideas?!
Thank you for your help!
Alex
alexkilo is offline
post #2 of 2 Old 03-11-2015, 10:34 AM
Liked: 0
Hello,
I have exactly the same problem . Did you somehow solved this issue?
Thx
MioRAB is offline
connection , network , problem , rx-v* , Yamaha
