Do I need a switcher? (Consumer level) - AVS Forum | Home Theater Discussions And Reviews
Old 10-19-2014, 04:01 AM - Thread Starter
realizment's Avatar
Guys I just moved and I am re-arranging some things.. I'm trying to figure out if I need an a/b/c switcher or not..
If I connect all my devices to my tv Samsung (65 es8000) via hdmi (ps4, dvr, Apple TV) and then out of the tv via optical into Samsung cheap surround will it play audio from each source? Or do I need to send the optical out directly to the Samsung from each device in which case I would need a switcher..
Any info much appreciated ...
realizment is offline
Old 10-19-2014, 04:15 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Depends on the quality of audio you want to listen to. A TV will generally only pass PCM 2.0 and DD 5.1 over the optical output (some can pass DTS 5.1), but none can pass the HD audio from a Blu Ray disc. If your Samsung AVR does not accept HDMI, then connecting the sources to the TV is likely your easiest option.
jdsmoothie is online now
Old 10-19-2014, 04:27 AM - Thread Starter
realizment's Avatar
Thank you.. Is there a way I can find out of my tv passes DD and DTS?
I am looking at View HD 4x2 Switcher will this pass the HD audio you speak of? The Samsung receiver only has HDMI out and optical in.. Thanks
Old 10-19-2014, 04:32 AM
jdsmoothie's Avatar
Liked: 5508
Sure. Either check your TV Owner's manual or simply connect the PS4 to the TV and play a DD and DTS movie track.
Old 10-19-2014, 04:39 AM - Thread Starter
realizment's Avatar
Thanks. Will the view hd 4x2 switcher pass HD audio do you know?
Old 10-19-2014, 04:42 AM
jdsmoothie's Avatar
Liked: 5508
Moot point as you don't have any device that can "accept" HD audio as HD audio can only pass over HDMI.
Old 10-19-2014, 04:55 AM - Thread Starter
realizment's Avatar
Understood.. So how does HD audio surround sound compared to Dolby and DTS? Huge difference? Any good starter kits for home consumer level worth looking at ?
Old 10-19-2014, 04:58 AM
Skylinestar's Avatar
Quoted: 1046 Post(s)
Liked: 182
You can only hear the difference if you have good speakers and room acoustics.
Skylinestar is online now
Old 10-19-2014, 05:00 AM
hotrod351's Avatar
Quoted: 14 Post(s)
i ues my optical output to my yamaha rx-a1020 for usb movies, it sounds great to me. cant notice any difference. might not be true surround sound but for me close enough. try it and see, or hear.
hotrod351 is offline
Old 10-19-2014, 05:12 AM - Thread Starter
realizment's Avatar
Thanks guys. Yea thought so.. For tv I don't care too much I just like decent sureound.. But for my studio the acoustics and speakers cost me a fortune and that's only 2 sets of stereo and sub haha..
Does anyone know if the Samsung tv will pass DD or DTS trough optical as i don't have a means to try right now but would like to know before ordering switcher. Thanks
Old 10-19-2014, 05:41 AM - Thread Starter
realizment's Avatar
I just read the manual online and mentions nothing.. But from what I can find about Samsung TV's they do not pass DD or DTS trough Optical.. Except for the newer 9000 series .. I actually used to have the 55 9000 but the 65 es 8000 replaced it.. So if anyone knows for certain about the 8000 please let me know. Thanks
Old 10-19-2014, 03:12 PM - Thread Starter
realizment's Avatar
Any ES8000 owners chime in?
