cheapest receiver with Audyssey for 5.1 setup? - AVS Forum
 1Likes
  • 1 Post By Glenn Baumann
post #1 of 5 Old Yesterday, 01:46 PM - Thread Starter
matthewmon's Avatar
I just need to figure out what the cheapest acceptable receiver is for my 5.1 home theater setup? Even if it is an older model...just want it to last a long time and do what i need it to do. Will have 60" plasma tv, bluray player and roku 3 hooked up. Must have a radio antenna for me to listen to the radio. It must have a good Audyssey program feature to calibrate the speakers. By the way how will i put the mic for that on my bed? I don't have a tripod... thanks!
matthewmon is offline
post #2 of 5 Old Yesterday, 02:05 PM
Glenn Baumann's Avatar
Quoted: 67 Post(s)
Liked: 29
I would definitely be looking to find a Denon X4000 model. It has the XT32 flavor of Audyssey which has the helpful higher filter resolution and Sub EQ HT which can EQ two subs if so desired.
The Denon X4000 can be found for some nice prices right now and it is LOADED with all the bells and whistles except for the new Atmos surround processing.
...Glenn
xcapri79 likes this.
Glenn Baumann is online now
post #3 of 5 Old Yesterday, 02:13 PM
xcapri79's Avatar
Quoted: 74 Post(s)
Liked: 81
The Denon X4000 also has HD radio tuner built in, and you noted you wanted radio.
HD radio offers superior sound and additional stations to the regular AM/FM radio and it is free.
xcapri79 is offline
post #4 of 5 Old Yesterday, 04:37 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 1367 Post(s)
Liked: 1596
Also, buy a tripod.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST (Sat/Sun too if you leave message)
Call for pricing on Denon, Marantz, Yamaha, Pioneer Elite, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #5 of 5 Old Yesterday, 04:48 PM
afrogt's Avatar
Quoted: 245 Post(s)
Liked: 400
Depends what version of Audyssey you want. If just the basic version of Audyssey MultEQ any of the entry level Denon's will do such as the e300 or e400 or s900BT.
If you want Audyssey MultEQ XT then the x1000, x1100, x2000, x2100.
If you want Audyssey MultEQ XT32 then get the x4000 or x4100
http://www.audyssey.com/technologies/multeq/flavors
As far as calibrating the microphone on your bed...order a tripod. They're only about $10.
http://www.ebay.com/itm/40-Light-wei...item19e95a2fff
http://www.ebay.com/itm/40-Light-wei...89184255&rt=nc
Afro GT
afrogt is offline
User Tag List
