Denon 1712 Coax Video Input - AVS Forum
post #1 of 2 Old 10-22-2014, 07:36 PM - Thread Starter
Liked: 0
I recently cut my ties with the cable company and will be switching to a digital antenna. Does anyone know if the Denon 1712 supports a coax input, and will output HDMI back to the TV? Currently using Xbox One to route TV, thinking the OneGuide may be good for Antenna.
nathanh85 is offline
post #2 of 2 Old 10-22-2014, 10:00 PM
afrogt's Avatar
Quoted: 247 Post(s)
Liked: 401
No AV receivers have coax video inputs, nor do they have tv tuners.
If you've dumped cable then connect your digital antenna directly your HDTV and take advantage of its built in HD tuner.
If you want to then send TV sound to your receiver, connect it via the TV's optical output to the receiver.
The Xbox one has HDMI out so you can connect that directly to your Denon 1712 for audio and video which is then sent to the TV via HDMI.
Afro GT
afrogt is offline
User Tag List
