How to tell vacuum tube is gone bad?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-23-2014, 05:05 PM - Thread Starter
Liked: 0
I recently purchased primaluna prologue 3 and I connect with dynaudio bm6a.
First I saw is lights of three vacuum tubes are dim and
other lights of three vacuum tubes are bright.
Among 6, 1 of vacuum tube has little soot on wall.
When I connect output-2 with bm6a speaker (active speaker), the volume is very low even I tune max volume.
When I connect output-1 with the speaker, the volume is loud enough with 1/3 of preamp volume.
Are these symptom indicated bad vacuum tubes?
Any other way to check vacuum tube??
chunki84 is offline
post #2 of 9 Old 10-23-2014, 09:07 PM
Knucklehead90's Avatar
Quoted: 490 Post(s)
Liked: 422
When I was a kid there was a vacuum tube tester in most stores larger than a mom & pop neighborhood store. Not very common these days. Anyway - soot on the inside probably indicates something burnt up. I'd get all the tubes tested and replace any bad ones. Look for a local electronics repair shop - many of them still have tube testers. Bring lots of money! Nice preamp!
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 9 Old 10-24-2014, 06:01 AM
DonH50's Avatar
Quoted: 2096 Post(s)
Liked: 1662
Take it to a tech.
Dim may or may not mean anything; it depends upon the filament power and tube construction.
The "soot" may be the getter that is flashed to remove the final traces of gasses inside the tube. I couldn't tell without close inspection if what you are seeing is a problem or not.
If one channel is not working properly it may be a tube or something else. You could try swapping all the tubes between channels to see if the problem follows a tube or stays with the channel.
A tech can measure and assess the entire circuit.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #4 of 9 Old 10-24-2014, 09:41 AM
Class A's Avatar
Quoted: 388 Post(s)
Liked: 1052
Thumbs up
Certain tubes do not get very bright, I have Tung sol gold pin 12AU7's in my Audio Research SP16. The tube by it's nature does not get very bright. My guess your larger Power tubes {EL-34's, KT-120's} are brighter than your smaller tubes {12 AU7's, 12AX7's}. Prima Luna amps have a feature that will indicate if you have a bad tube. Also tubes are not very expensive unless you get into exotic NOS versions.
Class A is online now
post #5 of 9 Old 10-24-2014, 01:53 PM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
There are two options.
1. use a tube tester.
2. swap for new tubes to see what happens.
FMW is offline
post #6 of 9 Old 10-24-2014, 04:21 PM
Class A's Avatar
Quoted: 388 Post(s)
Liked: 1052
PrimaLuna products have a BTI (Bad Tube Indicator) system. Each power tube has a red LED light next to it. If the tube is bad the red LED will come on and put the Integrated into protection. Are any lights on??
post #7 of 9 Old 10-28-2014, 12:34 PM - Thread Starter
Liked: 0
i ordered new tubes matsu****a? not sure if they are good. i like stuff made in japan
i din't think primaluna prologue 3 has BTI. can't see any led light except front power indicator.
chunki84 is offline
post #8 of 9 Old 10-28-2014, 08:37 PM
Worf's Avatar
Quoted: 516 Post(s)
Liked: 277
Surprised Japan still made tubes. The only ones I knew that still did were former Soviet republics who still make them by hand. That is, brand new tubes, not NOS.
Worf is offline
post #9 of 9 Old 10-29-2014, 08:05 AM - Thread Starter
Liked: 0
my mistake. i used word "new" as replacement. i bought used matsu****a tubes.
chunki84 is offline
