Yamaha RX-V675 powering MA GX200 - AVS Forum
Old 11-26-2014, 02:05 PM - Thread Starter
Quoted: 20 Post(s)
Liked: 4
Hello all I am about to purchase a pair of monitor audio GX200 floorstanders and a GXC350 centre as an upgrade from MA radius 90 left and right channels and a Radius 200 Center.
My question is will my Yamaha RX-V675 be able to power the GX200s?
According to Yamaha the RX-V675 is capable of 90 watts RMS but MA say the GX 200s require an amplifier with 100 to 200 watts.
Now I read in another post that speaker sensitivity is crucial when pairing an amp to speakers.
The GX200s have a speaker sensitivity of 90db so am I right in saying that if one watt of power is applied to the speaker I will get 90db?
Then after that every watt will increase the decibels by three?
Or have I got my wires crossed?
Any help appreciated
Thanks Adam
AdamAttewell is offline
Old 11-26-2014, 09:56 PM
beaveav's Avatar
Quoted: 99 Post(s)
Liked: 329
At low levels, modest levels, and semi-loud levels, your Yamaha should have no problem at all powering the Monitor Audio speakers.
At ear-bleeding levels, or at loud levels in a very large room, it might struggle (ie, clip or go into auto-shutdown/self-protect mode due to thermal limiting).
Try it, and if it seems fine at the levels you like, it's good to go.
The Monitor Audio recommended 100-200 watts is kinda silly, by the way, unless they know just how loud you like to play them.
For every new thing I learn, I forget two things I used to know.
beaveav is offline
Old 11-27-2014, 03:30 PM - Thread Starter
Quoted: 20 Post(s)
Liked: 4
Thanks for your reply beaveav, in decibals what do you class as really loud?
Gear in this thread - rx-v675 by PriceGrabber.com
