**miniDSP DDRC-88A Official Thread**8-channel AI/AO Dirac Live in a box - AVS Forum | Home Theater Discussions And Reviews
 3296Likes
post #1 of 13255 Old 12-08-2014, 05:35 AM - Thread Starter
steveting99's Avatar
Quoted: 1838 Post(s)
Liked: 634
Guys,
This is a dedicated thread on the MiniDSP product called DDRC-88A home theater in a box for those who are interested in Dirac Live Room Equalization solution. Only applicable with existing pre/pro/receivers that have an 8-channel analogue output to separate amps.
What is Dirac Live?
Spoiler!
Details of the DDRC-88A are available here: http://www.minidsp.com/products/dirac-series/ddrc-88a
Wiring diagram hookup for the DDRC-88A:
Owner's manual is available.
Cost is under a grand USD - not including shipping.
  • For European AVS members, contact Homestudio with details provided by Keith Barnes in post number 522.
  • For UK AVS members, contact Kalibrate with details provided by Keith Barnes in post number 593.
  • The rest of the world will have to order from MiniDSP based in Hong Kong.
Again this is an external box solution for:
  1. those who have external amps to drive speakers; or
  2. those who have active speakers.
If you have a receiver with internal amps, sorry it's not going to help much.
The DDRC-88A has both balanced and un-balanced inputs via Phoenix terminal blocks. A solution for those with XLR pre-outs has been given by miniDSP in their forum thread post number 17019. MiniDSP recommends to:
  • buy a short XLR patch cable;
  • Cut it in the middle;
  • Use the XLR male to bare stripped wire for the DDRC OUT. You just "screw" the bare stripped wire to the pluggin phoenix connector we provide in the package (see user manual); and
  • Use the XLR female to bare stripped wire for the DDRC IN.
AVS member Jerry has provided step-by-step details for XLR cable connection in post number 729. Post up-dated to include heat-shrink for a more professional looking finish. Thanks Jerry!
Analogue input and output connection details.
  1. MiniDSP has confirmed that it's possible to have a mixture of balanced and unbalanced signals. One has to take care of the gain structure - see 2nd post for additional information.
  2. On the analogue input side; use either the balanced or the unbalanced connection - not both on a per channel input basis.
  3. It is also possible to have unbalanced input and balanced output or the other way around.
  4. On the output side, both the the balanced and unbalanced terminals are active; i.e. 'hot'. So both can be used at the same time.
Features:
  • Bypass of the DDRC-88A is available. Good for those who would like to compare their current flavor of room correction such as Audyssey, ARC, YPAO, MACC, AccuEQ, PEQ, etc. vs. Dirac Live. Note when Dirac Live is ON, the REQ within the pre/pro/receiver needs to be disabled with distances/levels set to zero. See Markus post number 611 for details.
  • Correction is adjustable for start and end frequency as well as tilting to a custom house curve. I.e. One can start from 20Hz up to 1kHz with a 10dB tilt and no correction below 20Hz or above 1kHz.
  • Can store up to 4 presets of adjustable room curves. Dirac Live has single seat positioning (often referred to as the money seat) or a wider sofa seating positioning measurement options. The single and sofa seat + 2 more can be saved into the presets. This would allow some flexibility in tuning the sound depending on listening situation. I.e. having family/friends over vs. critical listening by yourself. Note that an unlimited number of projects can be saved on the PC for loading into anyone of the presets.
  • Can do multi-zones. I.e. Up to four 2-channel stereo systems in the home, see post number 4 for additional details.
Current issues:
  1. Has a maximum of 7.1 channels.
  2. If you have height/wides/ceiling speakers (Dolby Atmos, Auro3D, DTS:X), you may want to consider an additional DDRC-88A solution to go beyond 8 channels. (Edit: AVS members westmd and Keith Barnes have successfully implemented a dual DDRC-88A setup. westmd in post number 4,900 and Keith Barnes in post number 8,675 with the tutorial in post number 8,683.)
  3. Sampling resolution is capped at 48kHz, might be a disappointment for those with multi-channel hi-rez files. I.e. 192kHz/24bit.
  4. Have to use MiniDSP's microphone for in room acoustical measurement with Dirac. Model number UMIK-1. Post number 18,754 in miniDSP forum explains the reasons for this.
  5. No remote trigger to start or IR code for ON/OFF operation. There could be a potential issue when the unit losses power - may cause a thump to the downstream speaker. Suggested to leave the unit on all the time and this may not please some.
Trouble shooting:
  1. If the front light is OFF and the switch mode power adapter is ON (i.e. showing a green light. Edit: Keith Barnes advised that not all units power adapter have a light to indicate it is powered ON in post number 8,937) most likely the internal fuse needs replacing. Specs for the fuse is 2Amp 250v 20mm x 5mm Slow Blow. Revised fuse rating by miniDSP as advised by Markus in post number 9,186.
ellisr63, quack724, stef2 and 4 others like this.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
Last edited by steveting99; 05-21-2017 at 05:50 AM. Reason: additional text for clarity
steveting99 is offline
post #2 of 13255 Old 12-08-2014, 05:35 AM - Thread Starter
Liked: 634
Datasheet technical details.
Gain Structure (important!)
Why does it matter?
Wanyne A. Pflughaupt explains in detail what gain structure is about and mixing of pro gear with commercial home gear.
Spoiler!
What are maximum input voltages for the DDRC-88A?
Spoiler!
What are the maximum output voltages for the DDRC-88A?
Spoiler!
Sample rate and resolution of A-->D then D-->A conversion: 48kHz/24-bits
Signal processing delay: about 13ms (based on this article by MiniDSP and post number 17,992 in the MiniDSP forum). If in the bypass mode, the latency will be very minimal in the order of few ms (e.g. 1~2ms) for the IO and buffering.
Power supply requirements: 12VDC@2A (24W)
Volume dial provided on face plate. Volume control is in the digital domain (32 bits). Will need to determine how far down the volume can be lowered before information is lost in the original signal(s).
No remote supplied! BYO. **Eidt: AVS member Jerry has provided a step-by-step guide to program the Harmony remote for the DDRC-88A in post number 915.**
For those with multiple sub setups, there could be some issues with how Dirac handles time alignment.
  • Follow Jerry's guide using the signal path: single LFE channel out of your pre/pro/receiver/AVR ---> DDRC-88A sub input channel ---> DDRC-88A sub output channel ---> an external box solution (such as the 2x4) ---> to individual subs LFE input.
  • This would have multiple A/D conversions, but the intent is to initially get multiple subs time aligned first before applying Dirac Live filters to a single sub channel.
  • Further clarification from miniDSP is required on how intends to integrate multiple subs. 1st step is to choose custom system under system configuration. Select sub for the appropriate channel.
  • MiniDSP has confirmed that "..the Subwoofer check box does change the sweep signal and does change the way the filter is being calculated. It's recommended to make sure the signal is treated correctly." See post number 17568 in miniDSP forum.
Suggested 9 position mic pattern given by Flavio of Dirac to learn about one's room's acoustic response.
Spoiler!
Be sure all speakers can 'see' the mic when positioning. Red dot is the 1st position and the most important - center of head. This is where levels and distances will be determined by Dirac Live for all connected speakers. There's four positions (yellow dots) above the 1st position (red dot) in a random pattern. Another four positions (again yellow dots) below the 1st position (red dot) in a random pattern. Adjust the height above/below the 1st position to get the best acoustic response within the room.
For those who have bought a calibrated UMIK-1 mic from Cross Spectrum Labs, MiniDSP has confirmed that the 90 deg calibration file can be used for carrying out Dirac setup and measurements! **Edit: MiniDSP has confirmed that the sensitivity factor is not required by Dirac Live in post number 17534 in the miniDSP forum.**
Firmware updates that MiniDSP has advised:
23-Jan-2015: Bug fixes for levels issues, clearing presets and master volume in post number 17,599 of MiniDSP forum. This has been fixed on 2-Feb-2015. See post number 1664 and the subsequent post by Markus.
15-Apr-2015. New version of Dirac Live Calibration Tools with firmware update. Details of bug fixes and user interface improvements given in post number 3,567 by Jerry. This post also gives a guide on how to up-date the firmware on the DDRC-88A. +1 to Jerry for this!
quack724 and kbarnes701 like this.
Last edited by steveting99; 08-12-2015 at 09:04 PM. Reason: additional text for clarity. Firmware update. Up-date for gain structure (with flowchart). New version for DLCT.
post #3 of 13255 Old 12-08-2014, 05:35 AM - Thread Starter
Liked: 634
Multi-channel amps that can be used with DDRC-88A.
Crown CT-8150. Fanless design. Balanced inputs=YES (via Phoenix type). Unbalanced inputs=YES (via Phoenix type). No Remote Trigger, but has AUTO standby + deep sleep toggle - need to check if this is the same. Amp type=Class D. Energy efficient, small form factor and lighter weight. Power rating=8x125W into 8 ohms. Support for 4 ohm loads. THD=0.05%. Sensitivity=1.4V. Signal to noise ratio=110dB. (+1 to Skylinestar for this rec)
Cost (MRSP): $2,500 (approx.)
Link: http://www.crownaudio.com/row/comtech-drivecore.html
Availability from Amazon here: http://www.amazon.com/CT8150-Amplifi...s=crown+ct8150
Review by Andrew Robinson here: http://www.arccinema.com/crown-ct815...ore-amplifier/
Emotiva XPA-7. Fanless design. Balanced inputs=YES (via XLR). Unbalanced inputs=YES (via RCA). Remote Trigger=12VDC. Amp type=Class A/B. Power rating=7x200W into 8 ohms. Support for 4 ohm loads. THD=0.02%. Sensitivity=1.4V. Signal to noise ratio 117dB.
Cost (MRSP): $1,599
Link: https://emotiva.com/products/amplifiers/xpa-7
Behringer NU4-6000 iNuke. Uses active cooling with fans. Balanced inputs=YES (via XLR). Unbalanced inputs=YES(via professional 1/4" TS/TRS plug). No Remote Trigger. Amp type=Class D. Power rating=4x440W into 8 ohms (will need two of these units to go with one DDRC-88A but still lower cost than most multi-channel amps). Support for 4 ohm loads. Note: Uses professional Neutrik SpeakON power terminals and connectors. THD=0.2%. Sensitivity=0.775V. Signal to noise ratio 100dB.
Cost (MRSP): $525
Link: http://www.behringer.com/EN/Products/NU4-6000.aspx
Availability from Amazon here: http://www.amazon.com/Behringer-NU4-...inuke+nu4-6000
Yamaha MX-A5000. Fanless design. Balanced inputs=YES (via XLR). Unbalanced inputs=YES (via RCA). Remote Trigger=12VDC. Amp type=Class A/B. Power rating=11x150W into 8 ohms. This will do the full Atmos speaker setup of 7.1.4/9.1.2. Support for 4 ohm loads on European models - need to check if USA models are the same. THD=0.06%. Sensitivity=1.3V. Signal to noise ratio 116dB.
Cost (MRSP): $2,999.95
Link: http://usa.yamaha.com/products/audio...a5000_black_u/
Available from Amazon here: http://www.amazon.com/Yamaha-MX-A500...amaha+mx-a5000
NAD M27. Fanless design. Balanced inputs=YES (via XLR). Unbalanced inputs=YES (via RCA). Remote Trigger=12VDC. Amp type=Class D using Hypex nCore, energy efficient, small form factor and lighter weight. Power rating=7x180W into 8 ohms. Support for 4 ohm loads. THD=0.005%. Sensitivity=1.3V. Signal to noise ratio 120dB.
Cost(MRSP): $3,999.99!! Expensive...
Link: http://nadelectronics.com/products/m...ower-Amplifier
Available from Amazon here: http://www.amazon.com/NAD-Electronic...ywords=NAD+M27
Outlaw Audio Model 7200/7125/7075 series (the last three digits represent watts). Fanless design. Balanced inputs=NO. Only Unbalanced inputs via RCA available. Will have to step up to the higher end and more expensive balanced amps (Model 7700/7900) for balanced inputs. Remote Trigger=12VDC. Amp type=Class AB (need to confirm). Power rating for the top end Model 7200=7x200W into 8 ohms. Support for 4 ohm loads. THD=0.05%. Sensitivity=1.43V. Signal to noise ratio 119dB. Note that only 115VAC is available and Outlaw Audio does not ship international.
Cost(MSRP): $1,499 (Currently on sale)
Link: http://outlawaudio.com/products/7200.html
Parasound ZoneMaster Model 1250. Fanless design. Balanced inputs=NO. Only Unbalanced inputs via RCA available. Remote Trigger=12VDC (Overall + individual channels). Amp type=Class AB for input and Class D for output. Energy efficient, small form factor and lighter weight. Power rating=12x50W into 8 ohms. Can be bridged into 6x160W into 8 Ohms. Support for 4 ohm loads. Note: Uses phoenix power terminals and connectors. THD=1%. Sensitivity=0.7V. Signal to noise ratio 112dB.
Cost(MSRP): $2,495 ..(Not cheap)
Link: http://www.parasound.com/nc/1250.php
Axiom Audio ADA-1250. Fanless design. Balanced inputs=YES (via XLR). Unbalanced inputs=YES (via RCA). Remote Trigger=12VDC. Amp type=Class D. Power rating=8x156W into 8 ohms. Support for 4 ohm loads. THD<1%. Sensitivity=1.5V. Signal to noise ratio 103dB.
Cost(MRSP): $3,420.00! Expensive... There is a cheaper ADA-1000 version that has only RCA inputs.
Link: http://www.axiomaudio.com/1250-amplifier#t-3
Available from Axiom Audio directly.
D-Sonic M3-2800-7. Fanless design. Balanced inputs=YES (via XLR). Unbalanced inputs=YES (via RCA). Remote Trigger=12VDC. Amp type=Class D. Power rating=7x400W into 8 ohms. Support for 4 ohm loads. THD<0.03%. Sensitivity=1.8V. Signal to noise ratio 120dB.
Cost(MRSP): $2,975.00! Not cheap.
Link: http://www.d-sonic.net/products/mult...el-amplifiers/
Available from D-Sonic directly.
Home Theater Direct DMA-1275. Fanless design. Balanced inputs=NO. Only Unbalanced inputs via RCA available. Remote Trigger=12VDC. Amp type=Class D. Energy efficient, small form factor and lighter weight. Power rating=12x65W into 8 ohms. Can be bridged into 6x150W into 8 Ohms. Support for 4 ohm loads. THD=0.04% with individual channels and THD=0.09% in bridge mode. Sensitivity=? Signal to noise ratio ?
Cost(MSRP): $1,199
Link: http://www.htd.com/Products/multi-ch...fiers/DMA-1275
Audio Design Associates PTM-1260. Uses active cooling with fans. Balanced inputs=NO. Only Unbalanced inputs via RCA available. Remote Trigger=12VDC. Amp type=Class AB. Power rating=12x75W into 8 ohms. Can be bridged into 6x265W into 8 ohms. Support for 4 ohm loads. THD=0.05% with individual channels at 8 ohms. Sensitivity=0.6V. Signal to noise ratio >100dB
Cost(MSRP): $6,000 (expensive)
Link: http://www.ada.net/products/av/ptm_1260.php
MiniDSP PWR-16. Fanless design. Balanced inputs=NO. Only Unbalanced inputs via RCA available. Unbalanced inputs=YES (via RCA). Remote Trigger=12VDC. Amp type=Class D. Energy efficient, small form factor and lighter weight. Power rating=16x25W into 4 ohms. Maximum total available power is 400W for 80 seconds. Can be bridged into 8x50W into 8 Ohms. Support for 4 ohm loads. THD=0.1% at peak power in bridge mode. Sensitivity=0.92Vrms. Signal to noise ratio 110dB.
Cost(MSRP): $1,199
Link: http://minidsp.com/products/power-amplifiers/pwr-16
Onkyo PA-MC5501. Fanless design. Balanced inputs=YES (via XLR). Unbalanced inputs=YES (via RCA). Remote Trigger=12VDC. Amp type=Class A/B. Power rating=9x150W into 8 ohms. (150W is for just for 2-channel stereo between 20Hz to 20kHz) Support for 4 ohm loads. THD=0.05% (half power). Sensitivity=1V. Signal to noise ratio 110dB.
Cost(MSRP): $1,899
Link: http://www.uk.onkyo.com/en/products/...501-59358.html
Monoprice Monolith 7 Amplifier. Fanless design. Balanced inputs=NO. Unbalanced inputs=YES (via RCA). Remote Trigger=12VDC. Amp type=Class A/B. Power rating=7x200W into 8 ohms. Support for 4 ohm loads. THD=0.03% (half power). Sensitivity=1.6V. Only available for US voltage power supply.
Cost(MSRP): $1,499
Link: http://www.monoprice.com/product?p_id=14566
post #4 of 13255 Old 12-08-2014, 05:36 AM - Thread Starter
Liked: 634
Useful posts in the thread.
  • Jerry's simplified explanation for gain matching subs in post number 4,668.
  • Jerry's guide for using MiniDSP 2x4 to Time-Align Multiple Subs with Audyssey in post number 383. Thanks Jerry!
  • Jerry's guide on How to Use a Harmony Remote to Learn DDRC-88A Remote Commands in post number 915. +1 to Jerry!
  • Jerry's recommended guide for setting up levels during initial calibration in post number 5,414. Comparison of setting up levels between DLCT and Jerry's recommended guide is given in post number 5,439. Note that DLCT level setup results in a lower volume output and thus a lower signal to noise ratio.
  • Jerry's comparison of Audyssey XT32 vs. Dirac Live in post number 1,807. REW ETC graphs on left channel with before and after Dirac Live in post number 1,632.
  • Jerry's idea on fine tuning Dirac Live in post number 3,277.
  • Jerry's notes on creating custom filters in post number 6,326. The general idea is to lower the "ski slope" as Dirac works best by cutting peaks and the maximum boost Dirac can do is +10dB.
  • Jerry's brief guide on creating custom target curves with Dirac Live. The guide includes creating speaker groups to allow correction filters to be in place an octave above and below the crossover point so it is more balanced.
  • Setup for initial configuration of the DDRC-88A given by Markus in post number 611. Thanks Markus!
  • Implementing a subsonic filter on the sub channel by Markus in post number 2,946. Cool idea by Markus to protect sub woofers from over excursion! Thanks again Markus!
  • Suggested Harmon curve in post number 3,042 by Markus.
  • Procedure for level-matching of 2 subs in post number 9,359 by Markus.
  • Keith Barnes first report on the DDRC-88A in post number 2,042.
  • How to set up levels and delays for non-Dirac Live speakers given by Keith Barnes in post number 8,314.
  • Keith Barnes setup guide for dual DDRC-88A units for Atmos/Auro3D/DTS:X object audio in post number 8,683. Also available in Keith's signature.
  • Multi-zone setup application note given by MiniDSP. Thanks to TimoJ for the heads-up in post number 3,956.
  • Review of the DDRC-88A and comparison between Pioneer MCACC Pro vs. Dirac Live with graphs by imagic in post number 4,956. +1 to Mark for the great review.
  • dryeye comparison of YPAO vs. Dirac Live frequency response in post number 6,563 and ETC graphs in post number 6,637.
  • KevinG has worked out the codes to control the DDRC-88A via WiFi vs. IR remote in post number 9,869. Thanks Kevin for your hard work!
Subjective listening impressions by owners.Current owners list of DDRC-88A complied by Jerry in post number 2,341.
millst, quack724, catonic and 2 others like this.
Last edited by steveting99; 03-08-2016 at 11:21 PM. Reason: Harmony remote guide for DDRC-88A, owner's list and impressions
post #5 of 13255 Old 12-08-2014, 05:36 AM - Thread Starter
Liked: 634
External links, reviews and get-together on the DDRC-888A.
Dirac Live white paper.
Flavio on Dirac Live's graphs... how accurate? in the Computer Audiophile forum.
LA Home Theater meet report at Rayjr place by Scott Wilkinson.
House curves explained by Wanyne A. Pflughaupt over in Home Theater Shack forum. "...a house curve is perceived flat response as opposed to measured flat response..."
Scott Wilkinson got in touch with Dirac CEO about the required internet connection for the DDRC-88A in post number 124 of LA Home Theater GtG. Mathias reply verbatim:
"We use the server access both for a license check and for computing a certain part of the overall filter. The part that's done at the server concerns the time-domain correction, and, yes, that's done on the server to prevent piracy. This means that the first time you make a filter for a certain measurement set, you need to access the server. But if you then just want to change the target response, the server does not need to be accessed again. The time-domain correction does not change from a target change."
Review of the DDRC-88A by imagic in post number 4,956.
Interview with Mathias Johansson (CEO of Dirac Research) by Scott Wilkinson at Home Theater Geeks. Youtube video and subsequent discussion in the thread.
AVS member andyc56 has written an application called multi sub optimizer (MSO) in the following thread here: Optimizing subwoofers and integration with mains: multi sub optimizer
imagic (Mark Henninger) has written on the new bass management/active crossover features for the DDRC-88A the following thread here: MiniDSP DDRC-88A Dirac Live Update at CES 2016. Most likely a paid up-grade.
imagic and johnnygrandis like this.
Last edited by steveting99; 01-22-2016 at 04:53 PM. Reason: external links, reviews and GtG
post #6 of 13255 Old 12-08-2014, 05:48 AM
Gooddoc's Avatar
Quoted: 2943 Post(s)
Liked: 2059
Originally Posted by steveting99 View Post
The DDRC-88A has both balanced and un-balanced inputs via Phoenix terminal blocks. Will need a solution for those with XLR and pre-outs.
This is a possible solution http://www.amazon.com/Hosa-PHX-206F-.../dp/B003D83OWC
markrubin and xcapri79 like this.
Gooddoc is offline
post #7 of 13255 Old 12-08-2014, 06:07 AM
Mike Garrett's Avatar
Quoted: 6285 Post(s)
Liked: 4065
Originally Posted by Gooddoc View Post
Just make your own. I am doing that now. I buy 10' XLR male to XLR female. Cut in two and you have a cable to run from prepro to MiniDSP and a cable to run from MiniDSP to amp.
mjgarrett100@gmail.com
Mike Garrett is online now
post #8 of 13255 Old 12-08-2014, 06:10 AM - Thread Starter
Liked: 634
^ Gooddoc,
Thanks for the link! Will wait for others to chime in and confirm it's doable and will include your link in an edited post.
This MiniDSP in a box has put a spanner the home theater works for me. I've always heard great things about Dirac Live and never thought it could be available at a price that's semi-affordable to enthusiasts.
Now re-thinking about the whole process again.
Planning on getting one?
post #9 of 13255 Old 12-08-2014, 06:47 AM
Gooddoc's Avatar
Liked: 2059
Yea, you can do that. But then you have essentially made those cables into one trick ponies and connecting and disconnecting is a big hassle for 8 channels. Will save a few bucks in the short term though, so it's all about priorities .
Gooddoc is offline
post #10 of 13255 Old 12-08-2014, 07:02 AM
Liked: 4065
Guys,
Current issues:
  1. Does a maximum of 7.1 channels. I.e. No Atmos, Auro 3D, etc.
  2. If you have height/wides/ceiling speakers, this is not the right solution for you.
Why could you not run Audyssey to set speaker distance and levels, then turn off and run 5.1 or 7.1 through the MiniDSP and have the ceiling speakers run direct to the amps. Then everything except for the ceiling speakers would be EQed by Dirac.
Gooddoc and imagic like this.
post #11 of 13255 Old 12-08-2014, 07:02 AM
Gooddoc's Avatar
Liked: 2059
^ Gooddoc,
Maybe. But I give it 6-9 months tops and I predict we'll see a 13 channel version. That's a definite buy.
ellisr63 likes this.
Gooddoc is offline
post #12 of 13255 Old 12-08-2014, 07:09 AM
Rayjr's Avatar
Quoted: 181 Post(s)
Liked: 217
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
I think this unit from MiniDSP will be a great option for anyone wanting DIRAC room correction.
You will be able to have the same room correction as the DataSat and Theta units, but with an external box.
I really like this idea, as I can change my pre/pro or receiver..and my room correction can stay the same.
Good going MiniDSP...keep innovating.
RayJr
kbarnes701 likes this.
Rayjr is offline
post #13 of 13255 Old 12-08-2014, 07:16 AM
markus767's Avatar
Quoted: 3894 Post(s)
Liked: 1392
Current issues:
It can be used in an Atmos 5.1.2 setup.
What are those high resolution formats good for? Torture bats?
Mashie Saldana and Noman74656 like this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #14 of 13255 Old 12-08-2014, 07:19 AM
Liked: 4065
One half of my cable looks just like your picture, except for gold plated connections on XLR side and longer, so no more one trick than what you linked to. Also, not sure that connector will fit the MiniDSP. The Phoenix connections on my amps (looks like your link) will not fit the Phoenix connections on my MiniDSP10x10HD's and the connections on the new Dirac unit look to be exactly the same as what is used on the 10x10HD.
ellisr63 and Gooddoc like this.
post #15 of 13255 Old 12-08-2014, 07:21 AM
Rayjr's Avatar
Quoted: 181 Post(s)
Liked: 217
Current issues:
I don't see these as issues.
#1 "Does a maximum of 7.1 channels. I.e. No Atmos, Auro 3D, etc."
#2 "If you have height/wides/ceiling speakers, this is not the right solution for you."
Here is the answer.....use 2 DDRC-88A this gives you 16 channels of correction...if you read the instructions..they say that you can custom configure the speaker input/output. I am guessing that the box does not care what the configuration is, as long as you configure it correctly.
This is the exact same principle that the JBL Synthesis system uses with there SDEC units.
Need more channels....add another unit...at least these are not $9K like the SDEC's
Just my $.02
RayJr
Rayjr is offline
post #16 of 13255 Old 12-08-2014, 07:31 AM
Liked: 4065
Other than more channels for speakers, the unit could use a second sub output, for those of us that use multiple subs. Especially when front and back of room.
post #17 of 13255 Old 12-08-2014, 07:52 AM
gonthorn's Avatar
Very exciting to see something like this at a reasonable price point.
Finally we can apply Dirac to decoded atmos tracks!
As mentioned before, I wonder about the possibility of adding a second minidsp unit for 16 channel processing, Out of a 7.4.4 setup I would put 5.2.0 on the first unit, and 2.2.4 on the second (that being the back surround and height surrounds + 2 extra subs). Could it be as simple as loading the same "target curve" on the 2 units to get all 16 channels processed the same?
One other question, which only time / testing will answer: how will this unit effect lipsync, I wonder how much latency will be introduced by the Dirac filters, and what happens if that lag exceeds the AVRs adjustment range? I think 500ms or so is a common range. If the video arrives first we need a way to "speed up" the audio, I think most AVRs are 0ms - 500ms delay ..... what if 0ms isn't fast enough to sync with the video.
Am I overthinking this ?
Can't wait for some user reviews when this starts shipping.
gonthorn is offline
post #18 of 13255 Old 12-08-2014, 08:07 AM
Rayjr's Avatar
Quoted: 181 Post(s)
Liked: 217
You have 8 sub outputs if you want.
RayJr
Rayjr is offline
post #19 of 13255 Old 12-08-2014, 08:27 AM
Liked: 4065
Delay concerns me to. Especially if not all of the channels go through the Dirac unit, like I was talking about above. My system would be pretty messy.
Prepro to Dirac unit for five speakers and one sub. (Could other subs be placed on unused channels?)
Dirac unit to two MiniDSP10x10HD's for LCR and subs. (LCR signal gets split into three separate channels for active 3-way LCR's.)
Dirac to amps for left/right surrounds. (I could run these two channels through 10x10HD so that it had the same delay as LCR and subs.)
10x10HD to amps.
Prepro direct to amps for Atmos speakers.
With Atmos speakers having the short route of direct from prepro to amps, delay on Atmos speakers, most likely would be slightly different. Also the adjustment in a prepro is for delay of audio and I am concerned that I might need delay of video.
post #20 of 13255 Old 12-08-2014, 08:49 AM
Liked: 4065
RayJr
I would need a lot more channels. I run six subs. Now if the other channels could be used. I could do the following, since my subs are group of three up front and group of three in the back.
Run five speakers and the two sub outs from prepro through DDRC-88A.
Run four Atmos speakers direct to subs.
Still worried about delay, since the LCR have to go through a couple MiniDSP10x10HD's. If this works, it sounds tempting. I have some questions into MiniDSP.
post #21 of 13255 Old 12-08-2014, 09:23 AM
kbarnes701's Avatar
Quoted: 6780 Post(s)
Liked: 5142
kbarnes701 is offline
post #22 of 13255 Old 12-08-2014, 09:39 AM
gonthorn's Avatar
With my projector my lip sync is set to 125ms delay for audio currently. As you said, we may need "video delay". My understanding: if the Dirac adds over 125ms delay to the audio I will not be able to compensate via the AVR. In other words, my lipsync would be set to 0ms, but the video could still potentially be faster than the audio.
That's my only real concern, and will keep me from buying on day one, hope my worries are unfounded. Interested to hear what Minidsp has to say.
gonthorn is offline
post #23 of 13255 Old 12-08-2014, 10:04 AM
Tin_Can's Avatar
Quoted: 274 Post(s)
Liked: 62
I'll just reiterate that my concerns are the same as many others.
1) Can I use two of these units for an Atmos setup?
2) If #1 is done, will it enable the use of 4 subs?
3) How much delay is introduced?
Otherwise, I'm very interested in this. Dirac has been great on my computer for 2.1 listening.
Edit: One more question: Is the auditorium option available on this unit?
Tin_Can is offline
post #24 of 13255 Old 12-08-2014, 10:18 AM
Liked: 4065
I am not worried about delay, if just using Dirac. I doubt that this device alone would add too much delay. My concern is if using Dirac on the base speakers and sub and direct for Atmos speakers. Even worse in my case, if I run everything except for Atmos speakers through the DDRC-88A and a MiniDSP10x10HD.
post #25 of 13255 Old 12-08-2014, 10:19 AM
kbarnes701's Avatar
Liked: 5142
2) If #1 is done, will it enable the use of 4 sub's?
Don't see why not. You’d connect, for example, Unit 1 to the 7 listener level channels and Unit 2 to the overheads. Then run two calibration runs, one for each unit. The apply your single target curve to both units. Sounds straightforward enough unless I am missing something.
I would ass-u-me that when miniDSP were testing this unit they took account of any delay that it introduces and compared that to the lipsync in their test systems and found no problems.
post #26 of 13255 Old 12-08-2014, 10:22 AM
kbarnes701's Avatar
Liked: 5142
Quite. One would assume that miniDSp have tested this unit and found no issues.
If the delay is a known quantity then it can easily be added manually by adjusting the distance settings of the non-Dirac channels. Or use two DD88s - that is the route I am drawn towards even though it doubles the cost.
post #27 of 13255 Old 12-08-2014, 10:44 AM
KurianOfBorg's Avatar
Quoted: 141 Post(s)
Liked: 27
How will you align multiple subs without purchasing additional hardware? I don't think the latency will exceed 16ms like the other Dirac unit.
KurianOfBorg is offline
post #28 of 13255 Old 12-08-2014, 10:47 AM
Tin_Can's Avatar
Quoted: 274 Post(s)
Liked: 62
I wonder if the target curve is stored on the computer and is available to load into the second unit. It may be difficult to exactly match the target curve of the two units, if done manually.
Tin_Can is offline
post #29 of 13255 Old 12-08-2014, 10:48 AM
Quoted: 141 Post(s)
Liked: 27
It's saved as a plain text file and can be loaded again.
post #30 of 13255 Old 12-08-2014, 10:50 AM
Tin_Can's Avatar
Quoted: 274 Post(s)
Liked: 62
^^ Great, thank you.
Tin_Can is offline
DDRC-88A , dirac live , minidsp , req
