Questions about a Denon S700W - AVS | Home Theater Discussions And Reviews
post #1 of 5 Old 12-08-2014, 06:37 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 4
Question Questions about a Denon S700W
I have connected my Denon S700W with 2 R5Bi's for the front speakers and 1 R5Ci for the center. I also have an Outlaw LFM-1 Plus as the Sub. I have 2 more R5Ci's for the surrounds but those wont be connected for a while. At this point I only have DirecTV and an HD TV connected via an HDMI connection.
The receiver when in auto mode only plays PCM to the 2 front speakers and not the center. What should I do to get the center to work in auto mode? Note: the center works in Movie mode.
Do I need to connect an optical audio cable from my DirecTV to my receiver?
Thanks! I have have more questions later in this thread.
jmed999 is offline
post #2 of 5 Old 12-08-2014, 07:19 PM
grasshoppers's Avatar
Quoted: 334 Post(s)
Liked: 202
Sounds like you need to enable dolby digital
In your directv HD receiver.
Go to the system set up menu
And then audio then select dolby digital.
You should have it set up this way
Directv box-hdmi to avr-avr hdmi out to TV hdmi in.
No need for optical cable unless you have
HDMI handshake issues between directv receiver
And your avr. (It happens)
grasshoppers is online now
post #3 of 5 Old 12-09-2014, 03:13 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 4
Oh, ok. So basically I need to change the setting in the DirecTV menu.
Yes that's how I have it connected.
How do I know if I have handshake issues?
jmed999 is offline
post #4 of 5 Old 12-09-2014, 03:28 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3584 Post(s)
Liked: 2150
When a PCM 2.0 channel is playing on DTV, you can press the MOVIE button on the remote and select DD PLII to simulate 5.1 audio.
For more helpful information on your new S900W, join us in the 2014 Denon AVR Owner's thread. Review posts 3-6 as well as the following information on HDMI handshake issue .....
The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #5 of 5 Old Today, 07:39 AM
Liked: 0
Firmware Update Error Denos AVR-S700W
I was update firmware for Denon AVR-S700W and have problem with wifi connection. After this display show Update retry and after connectionfail03 or connectionfail10E.
I was seeing this problem with different Denon models but I didn't find to S700W.
I tried install by USB but the receiver doesn't read the pendrive.
How can I resolve this big problem ?
chshenrique is online now
Gear in this thread - s700w by PriceGrabber.com
