Troubleshooting B&K AV5000 - AVS Forum
post #1 of 2 Unread Today, 03:22 PM - Thread Starter
Liked: 0
Question Troubleshooting B&K AV5000
Hello AVS Forum. I resultantly picked up a non-working B&K Components AV5000 5 channel amplifier for less then a scrap metal price.
I opened it up and found via a visual inspection;
On the power supply board;
R1 & R2 2W 100ohm resistors overheated and one had failed open
Amp boards;
R1, R1A, R1B (5 total) looked to have overheated in the past, so I replaced them, the old ones were a tiny bit out of range, but still functional.
C2, C2B, C12, C12A, C12B
A couple of the 100uF 100V capacitors looked a bit swollen, so I replaced them all.
Two of the + side fuses were blown, Ch. 1 & 4
I replaced everything that VISUALLY looked damaged. I am worried that whatever caused these problems will materialize when I plug the unit in to test it.
Suggestions on other things to test while she is apart and before applying power? I'm on a really tight budget, so if I cant get this thing running, no music for me for awhile..... Thank you in advance!
Name:	amp board.png
ID:	437434   Click image for larger version
Name:	power board.png
ID:	437442   Click image for larger version
Name:	ps board.png
ID:	437450   Click image for larger version
Name:	con 2 board.png
ID:	437458   Click image for larger version
Name:	con board.png
ID:	437482   Click image for larger version
ID:	437490   Click image for larger version
ID:	437498   Click image for larger version
Name:	power supply board.png
Nor_Cal_Grown is online now
post #2 of 2 Unread Today, 03:31 PM - Thread Starter
Liked: 0
pics
ID:	437538   Click image for larger version
ID:	437546   Click image for larger version
