Audyssey mic question - AVS | Home Theater Discussions And Reviews
post #1 of 7 Unread Yesterday, 02:06 PM - Thread Starter
vitod's Avatar
Quoted: 14 Post(s)
Can I use the Audyssey mic from an Intergra 9.8 to a 80.2?
Thank you
Panasonic AE-2000, Carada BW 120"
Paradigm Studio 40v3 x 2, Paradigm 690 v4, Paradigm ADP 470v3 x 4
Mach 5 IXL-18 build http://www.hometheatershack.com/foru...sub-build.html, Soundsplinter RPL-15 in 9cuft vented x 2 Peavey Low Rider 18 in 3cuft sealed x 3 (nearfield) Integra 80.2, Emotiva XPA-3, UPA-5, 3 x EP2500
vitod is online now
post #2 of 7 Unread Yesterday, 02:11 PM
Quoted: 22 Post(s)
Liked: 0
yes you can, and I used it on Yamaha and it's work will
w1000i is online now
post #3 of 7 Unread Yesterday, 02:15 PM - Thread Starter
vitod's Avatar
Quoted: 14 Post(s)
Thank you! Because the 9.8 mic (round, flat type) is much easier to work with than the bulky 80.2.
Awesome!
vitod is online now
post #4 of 7 Unread Yesterday, 09:43 PM
Steelman99's Avatar
Quoted: 36 Post(s)
Can you use a Audyssey mic, to do a MCACC calibration on a Pioneer receiver?
Steelman99 is offline
post #5 of 7 Unread Today, 07:49 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 2739 Post(s)
Liked: 1930
Thank you
No. The hockey puck mics have a different calibration curve than the tower mics.
"JD" – jd@avscience.com ; Call me --> 585-645-1006, AVScience - AVSForum sponsor and authorized dealer for AVRs and Speakers
7 days a week 8am – 8pm EST
Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #6 of 7 Unread Today, 07:57 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1930
Audyssey mics are specifically calibrated to be used with the Audyssey software. Using with any other brand would not be as ideal as using the brand's own calibration mic.
post #7 of 7 Unread Today, 09:03 AM
Quoted: 22 Post(s)
Liked: 0
When I used the Audyssey it gives me more constant value each time i did calibration with small tolerance compare with they YAPO mic.
