Nakamichi IA-1Z User Manual - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-03-2002, 03:45 PM - Thread Starter
nakhter's Avatar
I seem to lost my user Manual for Nakamichi IA-1Z receiver. Can some
one help me out send me one or guide me where I can get hold of it.
I can't figure out where does the subwoofer goes in the back panel.
I have hooked a separate amp for center channel and I need to hook up
the woofer.
Nadeem
nakhter is offline
post #2 of 3 Old 12-05-2002, 07:18 PM
I have the 1a-!z and the user manual.
Plug the sub-woofer in the RCA plug socket under the center channel center- bottom row in the group of 6 RCA plug sockets just left of the 5 speaker wire terminals.
The manual is 56 pages and available in exchange for good Karma. Where do you want it sent?
Failing that, I'm wanting to identify the performance of the D/C converters on the 1a-1z. This isn't indicated in the user manual, have you been able to find original marketing information on this unit? It's not available on the nakamich web site.
Eric
MinMan
Eric Minden is offline
post #3 of 3 Old 12-06-2002, 08:30 AM - Thread Starter
nakhter's Avatar
Thank You Very Much!
Sorry do not know any thing about the D/C converters on the 1a-1z.
Nakamichi Web Site is not very useful can't find any thing.
I have external Power-AMP hooked-up for the Center Channel in that
location that you mentioned. Not sure where the Sub would go or
not sure if that is the right location for external output for Center.
But the center seem to work just perfectly from this location.
I use to have my woofer hooked at one place and external AMP at
some another location. Since I moved the equipment and tried to
reconnect I forgot how I had it configured before. I remember following
one of the direction/diagram from the manual.
I appreciate it if you can mail it to me. I will send you a personal
memo with the address.
Nadeem
nakhter is offline
Closed Thread Receivers, Amps, and Processors
