Receiver turning off with half volume... - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By FMW
post #1 of 9 Old 05-24-2015, 07:19 AM - Thread Starter
tmman's Avatar
I have what is probably a pretty simple question to answer. I just setup a small outside audio system for the summer that consists of a Nakamichia RE-10 receiver, 4 Polk Audi Atrium 4 speakers, and 2 OSD Audio OVC300 volume knob controls (2 speakers on each control). Both VCs are set to 1/2 for impedance matching. When I push the receiver volume close to half way it will begin to turn on and off... going into a protection mode, I assume.
Do I just not have a large enough receiver to push these four speakers? Any help is greatly appreciated!
Best,
Travis
tmman is offline
post #2 of 9 Old 05-24-2015, 09:07 AM
FMW
FMW's Avatar
Quoted: 1066 Post(s)
Liked: 1239
Rewire the speakers in series. My guess is that you have an impedance problem.
Shadowed likes this.
FMW is online now
post #3 of 9 Old 05-24-2015, 09:23 AM
RayDunzl's Avatar
Quoted: 876 Post(s)
Liked: 1082
Try a different setting on the control. Try the 4x setting. The higher setting should be more protective of the amplifier. But you may get less volume at the speaker, and have to turn up the amp, and be back where you started.
Or, aim a fan at the receiver if it is heating up. You won't hear it if you are outside.
https://lib.store.yahoo.net/lib/yhst...rol-Manual.pdf
I'll be back later...
links::: 1.5RQ > digits > 1177a > OpenDRC-DI > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is online now
post #4 of 9 Old 05-24-2015, 10:42 AM
M Code's Avatar
Quoted: 304 Post(s)
Liked: 198
The OSD components are inexpensive and unreliable...
Also their power handling spec is bogus..
These type of cheaper, lower quality attenuators present a very strange load to the amplifier, and in certain instances can actually damage the amplifier.. The RE-10 is a good stereo receiver but does not like low impedances, so if the loudspeakers (Polk Atriums) are wired in parallel the impedance would be 4 Ohms. The suggestion for wiring the loudspeakers in series and maybe worth a try, however IMHO as an installer I don't like to wire loudspeakers that way. As then the impedance would be 16 Ohms and the RE-10 would have very limited power output...
In my experience since we do AV commercial & home installs, we stay away from the cheaper, lower quality brands as in the long run they are unreliable. And if I have to send one of my techs back out to troubleshoot/fix the system the profit has just been tossed out.. Note that the better brands of the volume attenuators are SpeakerCraft, Niles..
I hope that helps clear things up for U...
Just my $0.02...
M Code is online now
post #5 of 9 Old 05-24-2015, 02:22 PM
highfigh's Avatar
Quoted: 351 Post(s)
Liked: 105
Best,
Travis
Disconnect the speaker wires from the receiver and make sure A) only 1/2" of insulation has been removed and B) no strands from + or - is touching the other. Do this at the volume control, too. Doesn't matter which end, it's a problem.
While the speaker wires are off of the receiver, measure the resistance on the speaker wires. I doubt that receiver likes 4 Ohms, regardless of the name on it.
I connected one of these to a six pair Niles speaker selector with volume controls and it never cut out. It didn't really sound great at mid-high level with all speakers playing, but that was never the intended configuration, anyway- we always planned on using a bigger power amp.
highfigh is online now
post #6 of 9 Old 05-24-2015, 03:29 PM
Quoted: 111 Post(s)
Liked: 37
If all Wiring is ok, increase the impedance matching to 4 or 8. This should help, though it will limit your max volume level
I suspect FMW is right as to the problem
dkfan9 is online now
post #7 of 9 Old 06-10-2015, 07:53 AM - Thread Starter
tmman's Avatar
Hi All,
Thanks for the comments. I just found out that the speaker wire that was run is 18 gauge. Could having this small of a wire be causing these issues?
tmman is offline
post #8 of 9 Old 06-10-2015, 08:22 AM
jaddie's Avatar
Quoted: 222 Post(s)
Liked: 102
Hi All,
No, if anything, it may help slightly if the wires are very long. If you have audio in all speakers, nothing is shorted. I'll go along with the impedance suggestion...get it up to 8, or at least higher than 4. Don't worry about the limited maximum volume just yet.
jaddie is offline
post #9 of 9 Old 06-10-2015, 08:33 AM - Thread Starter
tmman's Avatar
Thanks... I will adjust the VC's to do so and see if it helps.
tmman is offline
