Any sub $1k 7.1.2 atmos receivers? Keep 7.1 or move to 5.1.2 with Atmos?? - AVS | Home Theater Discussions And Reviews
post #1 of 7 Old Today, 08:29 AM - Thread Starter
slopokdave's Avatar
I've currently got a 1080p Pioneer Elite receiver, running 7.1. I'm getting a new 4K TV so I need to update the receiver too....
I was looking at the Pioneer VSX-90 but I don't think it will do 7.1.2. So should I move to 5.1.2 or is there another receiver that would let me add Atmos enabled speakers and keep my 7.1? The $800 of the VSX-90 was pretty much at the top of my budget.
TIA,
-Dave
slopokdave is offline
post #2 of 7 Old Today, 09:04 AM
doctor15's Avatar
Quoted: 13 Post(s)
TIA,
-Dave
IDK of anything in your price range at the moment. The rumors indicate more Atmos / HDCP 2.2 receivers will be released over the summer and early Fall, so if you want 7.1.2, you should probably wait.
This might be a dumb question, but what 4k source do you have that will require you to upgrade your AVR immediately? I would keep your 1080p AVR for now, let your TV upscale to 4k, then upgrade your AVR in a few months once there is one better suited to your needs / budget.
doctor15 is online now
post #3 of 7 Old Today, 09:07 AM - Thread Starter
slopokdave's Avatar
Thanks for the response! I didn't think about keeping my current receiver. 4k content that we could stream would be netflix, amazon... same as everyone else. However we do have a pair of the new Phantom 3 drones that shoot 4k. We don't have anything to watch our beautiful 4k video on though.
post #4 of 7 Old Today, 09:11 AM
doctor15's Avatar
Quoted: 13 Post(s)
There aren't too many streaming devices that output 4k ATM, so you would likely want to use your TV's built in applications, which would not be passing video through your AVR.
As far as your captured video, how do you currently connect it to your TV? I'm assuming the sound isn't 5.1 anyways so you can probably just connect it directly to the TV.
post #5 of 7 Old Today, 09:24 AM - Thread Starter
slopokdave's Avatar
Dang I didn't think about that either. We use Chromecast (on the AVR) to stream right now, but can use the TV apps like you mentioned. But then I need to audio-out from my TV to my AVR (would need to change source??).
post #6 of 7 Old Today, 10:20 AM
Movie78's Avatar
Quoted: 259 Post(s)
Liked: 43
The Pioneer VSX-90 AVR will do 7.2 DTS HD MA /DOLBY TRUEHD and 5.2.2/ATMOS
Movie78 is offline
post #7 of 7 Unread Today, 04:47 PM
doctor15's Avatar
Quoted: 13 Post(s)
Your Chromecast is only 1080p, so the video is unlikely to benefit from a new AVR. Yes, you will need audio out from your TV. Your setup will look something like this:
Current 1080p sources should remain connected through AVR, just like before
Code:
 |1080p Source|   --------> |AVR|  -------> |TV|
When using 4k Apps on your TV, the Video is already on your TV and you can send 5.1 back to your AVR either via HDMI ARC or an Optical Digital Cable, so you will just switch to the proper input
Code:
 |AVR|  <--[HDMI or Optical Digital]---- |TV|
For your drone, you didn't mention what device you use for playback or how it connects. If your TV can play 4k video files, you just plug a USB stick into the TV to playback in 4k, and it will pas the audio back just like above. If your drone has HDMI, you can also just plug it right into the TV.
When you upgrade to a new AVR (make sure it supports HDCP 2.2) everything will work exactly the same except future devices like your 4k blu-ray player can be plugged directly into your AVR.
