Pioneer SC-79 where to plug in wireless headphones - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-11-2015, 08:44 AM - Thread Starter
OfSoundMind's Avatar
Hooking up some wireless headphones via RCA jacks to the SC-79, I have tried almost all of the audio outs but cannot find where I can hook them up so that the output switches with the input selected. I would rather not hook-up to the front headphone jack.
OfSoundMind is offline
post #2 of 7 Old 06-11-2015, 09:15 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4412 Post(s)
Liked: 2372
Zone 2 pre-outs
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #3 of 7 Old 06-11-2015, 09:45 AM - Thread Starter
Zone 2 pre-outs
JD, Thanks for your reply. Thought of using the zone 2 pre-outs but that would preclude me using zone two for music while watching something else. I guess it may be an ok compromise. Just seems lame that they wouldn't have a main pre-out.
Thx!
post #4 of 7 Old 06-11-2015, 09:53 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2372
It does have a main zone FL/FR pre-out as well which I thought you said you tried?
post #5 of 7 Old 06-11-2015, 10:23 AM - Thread Starter
The problem with that is that when you mute the speakers (which you usually do with headphones) the pre-out mutes as well.
The issue using zones in this way is that I have to patch the analogue audio from each source to the RCA inputs on the SC-79 because the sources that use HDMI (most of them) can not pass through audio to the zones. Quite a hassle.
post #6 of 7 Old 06-11-2015, 10:42 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2372
Another option would be to use an HDMI --> analog converter between the sources and the AVR.
http://www.monoprice.com/Product?c_i...seq=1&format=2
post #7 of 7 Old 06-11-2015, 10:48 AM - Thread Starter
I have analog out if I need it from each device already (I have an optical to RCA converter on my AppleTV for music) but even doing that doesn't work if you have speakers on both zone 2 and 3 (which I do) because the sound will come out of the speakers in those zones when using the headphones.
I guess what I was looking for was a monitor out but looks like I will need to use the headphone jack on the front. Would have been nice to have a headphone out on the back.
Thanks for all of your time thinking about this!
