Need your advice - Anthem MRX310/510 or Marantz SR6009 - AVS Forum | Home Theater Discussions And Reviews
Old 06-15-2015, 09:00 AM - Thread Starter
Liked: 1
I'm building a new system that I plan to use equally for music and for movies. I just picked up a set of Epos Epic 5 Towers yesterday and I am looking to now add a receiver to the mix (still thinking about an amp/pre-amp setup too but maybe a receiver is better for me?). With my space, I intend to run a 3.1 system. I just want great sound quality and don't care much for 4K technology at the moment. I would like to eventually add a turntable and cd player to the system soon though.
I'm trying to decide between the Anthem MRX 310 or 510 or the Marantz SR6009. What would you recommend? Or would you recommend me go the amplifier/pre-amp route altogether?
Sorry for all the newbie questions. Appreciate the feedback!
freesole is offline
Old 06-15-2015, 09:30 AM - Thread Starter
Liked: 1
+ add Denon X4100 as an option as well
freesole is offline
Old 06-16-2015, 03:25 AM
Quoted: 217 Post(s)
Liked: 75
Sound quality Anthem, features Marantz. Whichever is most important to you. If you need 5 channels or less the MRX-310 will be fine. If you like playing loud above moderate levels an amp is beneficial, you could add an amp to either of those models if needed.
Ellebob is offline
Old 06-16-2015, 05:47 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4411 Post(s)
Liked: 2372
The Denon X4100W with Audyssey MultEQ XT32 will provide better audio quality over just the XT version in the SR6009. ARC compared to XT32 will be comparable with some preferring one over the other as they use different technology. Select the model that offers the features/inputs/outputs you want and is within your budget.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
Old 06-16-2015, 09:21 PM - Thread Starter
Liked: 1
I ended up ordering the Anthem MRX 510. I'll give it a try over these next 30 days and see how it sounds. My priority is sound quality. I think they all have the basic features that I want.
If this fails, I might just end up purchasing the Parasound A23 amp and Parasound P3 pre-amp instead. If any of you have thoughts on how good this combo is, please do let me know
freesole is offline
Old 06-17-2015, 06:29 AM
Quoted: 217 Post(s)
Liked: 75
The Parasound is very nice but only 2.1 and all your sources need to have analog outputs. If you are going to do 2.1 instead of 3.1 it is certainly a nice option. It would probably depend on how good Anthem's ARC room correction does in your room
Ellebob is offline
Old 06-18-2015, 04:31 PM - Thread Starter
Liked: 1
I ended up with the MRX 510 and will be setting up soon Can't wait to hear it perform.
skip61 likes this.
freesole is offline
Old 06-18-2015, 06:08 PM
skip61's Avatar
Quoted: 41 Post(s)
If sound quality is your priority then you won't be disappointed . I had a Pioneer Elite receiver before with all the bells and whistle and when I decided to change me too my priority was sound quality over the bells and whistle.
I did a lot of research and ended up buying the MRX510. I am very satisfied with it and ARC2 is far superior to the MCACC of Pioneer.My speakers never sounded better!!
skip61 is offline
