Advice sought - new system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-16-2015, 02:44 AM - Thread Starter
Liked: 2
Lightbulb Advice sought - new system
Want to build receiver and speaker system to replace Samsung soundbar. Will be used for music and movies, most of new content are purchased downloads from various sources.
Movies, I'm not too interested in big sound, but want to get some effects, but primary reqiurement is dialogue.
Thoughts and budget are 2 fronts and center speaker. Might add sub' at some point.
Speakers, either: MA Silver 6 or B&W CM8 S2
. Receiver SR5009 or RX-A740.
Any comments, thoughts appreciated. Toying with idea of adding rear/surround speakers as wireless in future, not sure if it's possible or how. Just a thought. Thanks
TEREZASRBOVA is offline
post #2 of 9 Old 06-16-2015, 04:49 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4411 Post(s)
Liked: 2370
Regarding the AVR, the SR5009 uses Audyssey which can EQ both the speakers and the sub (when you get one) whereas the A740 can only EQ the speakers. Additionally feature wise, the SR5009 is more on par with the A840.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #3 of 9 Old 06-16-2015, 07:59 AM
GregLee's Avatar
Quoted: 397 Post(s)
Liked: 139
Get a 5.1 receiver, even if you have immediate plans only for left, center, and right speakers. A 5.1 receiver will work with just left and right speakers -- you can add others as convenient.
Everybody needs a sub.
Greg Lee
GregLee is offline
post #4 of 9 Old 06-16-2015, 09:27 AM
zgeneral's Avatar
Quoted: 581 Post(s)
Liked: 122
On a budget? Go used. You can get a good 5.1 system for less than what you'd pay for what you're looking to do.
zgeneral is offline
post #5 of 9 Old 06-16-2015, 09:41 AM - Thread Starter
Liked: 2
thanks - too much hassle to buy used.
post #6 of 9 Old 06-16-2015, 09:45 AM - Thread Starter
Liked: 2
Listened to the MA Silver 6 with Yamaha and sound nice, although maybe a tad restrained, but speakers were box new. Listened to CM8 S2 with Marantz and sounds very nice, not sure which setup I prefer and side by side wasn't possible. A840 is outside budget.
More consideriung and possible relisten.
Thanks for comments.
post #7 of 9 Old 06-16-2015, 04:29 PM
kikkenit2's Avatar
Quoted: 287 Post(s)
Liked: 138
Check out the Onkyo 646. Has hdcp 2.2/hdmi 2.0a and atmos surround.
Best of all will include dts:x surround. Also has bluetooth/wifi and now airplay.
http://www.amazon.com/Onkyo-TX-NR646.../dp/B00WM1V9KU
http://avproductreviews.com/onkyo-tx-nr646-747-preview
http://www.onkyousa.com/Products/mod...class=Receiver
kikkenit2 is offline
post #8 of 9 Old 06-17-2015, 09:18 AM - Thread Starter
Liked: 2
Thanks. I See the new Yamaha rx50 series are a little closer to the Onkyo.
post #9 of 9 Old 06-17-2015, 02:11 PM
kikkenit2's Avatar
Quoted: 287 Post(s)
Liked: 138
Correct. Marantz will be 5010. Denon x2200. Onkyo 646. Yamaha A850 etc. All brand new models.
