Setting external amp gain? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Wayne A. Pflughaupt
post #1 of 15 Old 08-13-2015, 12:37 PM - Thread Starter
virtualrain's Avatar
Quoted: 143 Post(s)
Liked: 26
I've got a pair of mono block amps to drive my front L/R mains from pre-outs on my AVR. They both have a knob on them to adjust the gain. I'm guessing the best approach to setting the gain on an external amp (such as these) is to follow the same practise normally applied to sub-woofers...
- Set the gain to about mid-way
- Run room calibration and note the levels applied by software
- Adjust amp gain up or down until the calibration is applying 0 adjustment to levels
Or is there some other way?
virtualrain is online now
post #2 of 15 Old 08-13-2015, 12:50 PM
jdsmoothie's Avatar
Quoted: 4949 Post(s)
Liked: 2552
That should do it, but subs are generally far more efficient than speakers, so you'll need to likely raise the gain to at least 80% of max.
2015 Denon AVR thread ----> http://www.avsforum.com/forum/90-rec...dcp-2-2-a.html
Think your AVR is defective? Check the Owner's manual and do a factory reset 4-5 times if necessary.
jdsmoothie is offline
post #3 of 15 Old 08-13-2015, 01:40 PM - Thread Starter
Quoted: 143 Post(s)
Liked: 26
Roger that... thanks!
post #4 of 15 Old Yesterday, 01:54 AM
GIEGAR's Avatar
Quoted: 198 Post(s)
Liked: 530
Yes, there's another way if you're keen.
To optimise the performance of your new amps with the AVR, you'll need to take a deep dive into setting up the gain structure. The most comprehensive explanation and process I've seen on the subject - and admittedly I don't fully understand it myself - is this excellent multi-part sticky on HTS by @Wayne A. Pflughaupt .
Gain Structure for Home Theater: Getting the Most from Pro Audio Equipment in Your System
Happy gain structuring!
GIEGAR is online now
post #5 of 15 Old Yesterday, 05:00 PM
Wayne A. Pflughaupt's Avatar
Thanks for the kind words, Giegar.
Virtual, no need to wade through the whole article. Since you’re using your AVR as the pre-amp you can just gain-match the new amps to the AVR’s internal amp. You can find the “how two” on that in Part 8.
Wayne A. Pflughaupt
GIEGAR likes this.
Wayne A. Pflughaupt is online now
post #6 of 15 Old Today, 08:45 AM
GIEGAR's Avatar
Quoted: 198 Post(s)
Liked: 530
Thanks for dropping in Wayne. Thanks also for the tip that the "dive" doesn't have to be quite as "deep" as I indicated for proper gain-matching.
Your article has been my go-to reference for anyone enquiring about integrating pro amps into a home theatre system. The following quote is the crux of it for me, and you do a great job of proving it in your article.
Unfortunately, the maximum-levels canon is ill-advised and naive. The truth is that going to extraordinary lengths to max out the low-level signal fed from a home theater AVR to downstream professional gear, especially by using external signal-boosting devices, is often unnecessary and can even be detrimental to achieving optimal dynamic range. As it turns out, gain structure suitable for a mixed pro/consumer system is relatively easy to attain and seldom requires anything in the way of extraneous signal manipulation.
[BTW: My 10 year old son (a budding bassist) and I were both very impressed with your bass rig and beautiful basses shown in the article linked in your signature.]
post #7 of 15 Old Today, 10:52 AM - Thread Starter
Quoted: 143 Post(s)
Liked: 26
Wayne A. Pflughaupt
Is that the part where you drive one channel through the AVR amp and one through the external amp with pink noise and match the SPL?
post #8 of 15 Old Today, 12:51 PM
Driving speakers actually, but yes that’s it.
Wayne A. Pflughaupt
post #9 of 15 Old Today, 01:06 PM - Thread Starter
Quoted: 143 Post(s)
Liked: 26
Wayne A. Pflughaupt
Ok. Yeah. That's what I meant. It's definitely an easy way to do it. And I guess for someone that doesn't have an SPL meter, they can do a best guess by ear and then run the room calibration routine in this way to see what it wants to set the level on the Amp channel to and adjust by trial and error until both channels are the same.
Ps. The guide isn't all that clear to be honest. That one paragraph is essential but buried in a section on measuring noise v
post #10 of 15 Old Today, 01:17 PM
Sure, you can be get in the ballpark by ear, and the AVR will take care of the rest.
Understandable. However, the focal point of that section is determining background noise levels of outboard professional gear, not a how-to on level-matching an AVR to an outboard amp per se.
Wayne A. Pflughaupt
post #11 of 15 Old Today, 02:22 PM
Almost didn’t see your post, I sure wish AVS would fix their e-mail notification issues. It’s going on a year now - ridiculous.
But yeah, it’s much easier with an AVR as the front end as you have the internal amps as a reference for setting gains on an outboard amp. As long as the AVR has enough output voltage to drive the amp that is...
Thanks again for the kind words, Giegar.
Yeah, don’t know how long you’ve been hanging around the home theater forums, but it used to be everyone and his dog was saying “boost the signal,” especially when it came to digital processors like the Behringer DCX, and everyone else was buying it and passing it along to others. It was in on all the forums (or at least the ones I visited). However, I’ve noticed that you never see anyone floating that song and dance anymore. In fact, I can’t hardly find the “boost the signal” references I quoted in the article (i.e. dropping the quote into Google). It’s like everyone who wrote that stuff went back and deleted it after the article came out! If I had a part in putting that mythology out to pasture, I’m happy!
Thanks again! Kudos to the kid, he’s getting an early start. I think I was 12-13. Tell him to practice, practice, practice. You’ll never have the time to practice like you do when you’re young. I cut my teeth playing records and learning the bass parts (yes I’m that old).
I’ve made a few additions to “the family” that the two of you might like. Last time I tried to update the HT Shack page it wouldn’t let me for some reason, but my signature on the page linked below has links to close-ups of the new basses. It’s one of the niceties of being older with the kids out of the house, finally being able to afford some toys. I never had more than one bass at a time until a few years ago.
My Basses
Wayne A. Pflughaupt
GIEGAR likes this.
post #12 of 15 Old Today, 02:36 PM
RayDunzl's Avatar
Quoted: 987 Post(s)
Liked: 1171
I've got a pair of mono block amps...
What is their input sensitivity?
I'll be back later...
links::: 1.5RQ > digits > 1177a > OpenDRC-DI > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is online now
post #13 of 15 Old Today, 02:46 PM - Thread Starter
Quoted: 143 Post(s)
Liked: 26
Not specified... But reviews from others seem to indicate they interface well with consumer AVRs or other devices...
http://www.daytonaudio.com/index.php...amplifier.html
post #14 of 15 Old Today, 03:29 PM
RayDunzl's Avatar
Quoted: 987 Post(s)
Liked: 1171
1V sensitivity is mentioned in the Q&A here.
post #15 of 15 Unread Today, 04:07 PM
torii's Avatar
Quoted: 145 Post(s)
Liked: 40
if you bridge 2 amps together? should you adjust the gain on each individual amp? i have been happy with both my amps bridged and gain at 0...but in back of mind wonder if i should tweak with each amp gain controls? dont mean to hijack, just thinking this might apply here.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc800v, Klipsch synergy KSF 10.5 Subs: Velodyne HGS 12, VA 1512
torii is online now
