Dual receiver set up for additional surround channels? - AVS Forum | Home Theater Discussions And Reviews
Old 08-26-2015, 07:50 AM - Thread Starter
speeddeacon's Avatar
Quoted: 39 Post(s)
I've seen a few on the board that are using multiple receivers to add additional surround channels. I'm curious how this is accomplished from a connection and decoding standpoint.
speeddeacon
speeddeacon is online now
Old 08-26-2015, 07:54 AM
eljaycanuck's Avatar
Quoted: 456 Post(s)
Liked: 850
I'm curious, too. I've seen people using additional amps to power available-but-unpowered channels in their AVRs, but not using additional AVRs to "add" channels to their set-up.
eljaycanuck is online now
Old 08-26-2015, 08:00 AM
jdsmoothie's Avatar
Quoted: 5307 Post(s)
Liked: 2677
Addressing only the connection aspect (rather than surround processing), and depending on what connections are available on your old receiver, use the following instructions:
Receiver with multi analog inputs (this is preferred as it allows you to more easily amplify more than just 2 speakers):
1. Connect the primary AVR speaker pre-outs to be amplified to the old receiver's FL/FR multi analog inputs.
2. Select the source (eg CD) on the old receiver to be used
3. Set the audio input to EXT IN (ie. multi analog inputs) on the old receiver
4. Connect the speakers to be amplified to the FL/FR speaker posts of the old receiver
Receiver without multi analog inputs:
1. Connect the primary AVR speaker pre-outs to be amplified to one of the old receiver's stereo analog inputs (eg. CD)
2. Select that source (eg. CD) on the old receiver to be used
3. Set the old receiver to DIRECT mode
Regardless of the type connections used:
1. Factory reset the old receiver (see Owner's manual for this) to restore all settings to factory default (esp. speaker distance/level settings).
2. Raise the volume of the old receiver to at least 80-100% of maximum
Possible issue using an old receiver of the same brand as the primary AVR would be the remote controlling both AVRs, so unless either model has a unique Remote ID feature, you'll want to cover the IR sensor of the old receiver.
2015 Denon AVR thread ----> http://www.avsforum.com/forum/90-rec...dcp-2-2-a.html
Think your AVR is defective? Check the Owner's manual and do a factory reset 4-5 times if necessary.
jdsmoothie is offline
Old 08-26-2015, 08:02 AM
ALtlOff's Avatar
Quoted: 292 Post(s)
Liked: 119
Depends on what you're trying to accomplish, basic setup is simple, just split your input signal into both receivers and wire speakers accordingly.
But....
This is not needed for normal surround applications, you can accomplish the same thing by simply "correctly wiring" multiple speakers or splitting the low level output signal into separate amps then to the speakers, using separate amps also allows you to play with delays using a dsp, like the Mini-DSP.
The people I think you're referring to are the people trying to expand their options for Atmos & DTS-X, by using two receivers they are able to expand on the current speaker layout limitations with the formats, and in this instance the multiple receivers allow for extra "discrete" channels, not just duplicated surrounds.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
Old 08-26-2015, 08:37 AM - Thread Starter
Quoted: 39 Post(s)
I understand the idea of using the receiver as an external amplifier, but as ALtlOff described, I am curious about extra discrete channels, for example a discrete 15.2 /7.2.8 channel setup.
I'm assuming you need two receivers/SSPs with matching decoding capabilites (Neo:X, Atmos, DTS:X, Auro, etc.)?
So if you have four HDMI sources, such as a BluRay, a streamer, a satellite and a computer, you would put a 1:2 HDMI splitter on each source then connect them each to both SSP and then within the SSP set up the speakers that they were powering, L,C,R,SSL,SSR,LR,RR,FHL,FHR,FWL,FWR,FPL,FPR,RPL,RP R? Is that correct? How is volume controlled, by adjusting both SSPs?
speeddeacon
