is it better to passive bi-amp or not? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By DonH50
post #1 of 9 Old 08-30-2015, 01:52 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 1
Hi my apologies for opening a topic that has been discussed very frequently. Having read multiple forums and posts i cannot decide if it is worth it to hook up some wires in the 7.1 surround and passively bi-amp polks with a onkyo 526. I do not have an active crossover or an external stereo amp . Having tried to bi-amp i am not sure i noticed an improvement.
My main questions are:
Should I change de LFE channel crossover below 120 now that its bi-amp.
Also I noticed that i cannot hear anything very clearly in dialogues from the center channel seems so low and muffled not sure how I can improve this audessey set the center at -11 db...should i change that? if so what's the point of running audessey.
Finally should i set the surroind to active since i am bi-amping or I should leave them to on and let the receiver on bi-amp.
Not sure all of this is worth it if anyone has experience with receiver passive bi-amp ure help would be appreciated , thx
123go is online now
post #2 of 9 Old 08-30-2015, 03:14 PM
DonH50's Avatar
Quoted: 765 Post(s)
Liked: 545
I would not waste my time and wires but YMMV. It has been explained ad nauseum in numerous threads. A few hear differences; the majority here feel it offers no audible benefit in the vast majority of cases. At least some Onkyo units do allow you to set an internal crossover when bi-amping IIRC.
You should not change the LFE setting.
Were you able to hear the center OK before trying to bi-amp? Or is that a separate issue/question unrelated to bi-amping? Bi-amping may have changed the gain structure so you should re-run Audyssey. In any event, I would re-run Audyssey and/or bump up the center trim level to see if that helps.
FWIWFM - Don
dmarqueset likes this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #3 of 9 Old 08-30-2015, 10:33 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 1
FWIWFM - Don
thx,
sorry to ask but what is YMMV? My onkyo as the normal crossovers settings and there is no huge difference with changing that. I will try to see if I can change the center completely seems very week . Guess bi-amping isnt so bad to my perception the sound is less harsh than before but still feels like its coming from a can not completely alive as I want, but close and good enough i guess. thx again
123go is online now
post #4 of 9 Old Yesterday, 09:41 AM
Legairre's Avatar
Quoted: 148 Post(s)
Liked: 122
Originally Posted by 123go View Post
thx,
Your mileage may vary.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is offline
post #5 of 9 Old Yesterday, 07:34 PM
DonH50's Avatar
Quoted: 765 Post(s)
Liked: 545
^^^ What he said.
As for bi-amping, that has nothing to do with the sound of the center. Did you use a mic stand when running Audyssey, where was the mic positioned? It sounds like the center was not set up properly for whatever reason. Make sure it is pointed at the listening position.
post #6 of 9 Old Today, 05:24 AM
FMW
FMW's Avatar
Quoted: 1187 Post(s)
Liked: 1348
The right answer is that it is better not to do it. Passive biamplification adds complexity to the system without providing any benefit.
FMW is online now
post #7 of 9 Old Today, 06:42 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 1
^^^ What he said.
i dont have a mic stand i hold the mic in my hands does it make such a huge difference?
123go is online now
post #8 of 9 Old Today, 09:40 AM
DonH50's Avatar
Quoted: 765 Post(s)
Liked: 545
"Huge" is relative but yes, it can make a significant difference. You hands shake (even when you think they don't) and moving the mic around during measurements can corrupt the readings. Your body can also interfere with the calibration since it assume the mic is all by itself. You might think about getting an inexpensive boom microphone stand to hold the calibration microphone if you do not have one. That way you can put it right where it should be (ear level at the main listening position) and hold it rigidly without impacting the measurements. Mic stands can be had for from $20 to many hundreds of dollars. You can pick one up at a local store (Guitar Center or similar) or online. Here is an inexpensive one: http://www.sweetwater.com/store/detail/MicStdFBoomL
HTH - Don
post #9 of 9 Old Today, 11:33 AM
b curry's Avatar
Quoted: 120 Post(s)
Liked: 72
Yes, you really should use a mic stand for best results.
Position the mic mounted on a stand with the tip of the mic pointed up toward the ceiling. Follow all the instructions for your brand of room correction. Measurements are usually taken with the mic at ear level.
Trying to hand hold the mic will introduce unwanted reflections and probably some noise from your hand as it grips the mic. Your room correction software will try to correct for something that isn't really there during normal listening conditions.
b curry is online now
