4 channel EQ 1 input 4 outputs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-02-2015, 07:39 AM - Thread Starter
Liked: 0
Hi, I have a restaurant with a 4 channel amp (Yamaha XM4180 - 4-channel compact power amplifier 180W/8 ohm x 4ch).
The problem I have is that I need to be able to equalize (hi-mid-low) each area independently. Is there something like an inverted 4 channel mixer? I mean something with 1 input and 4 outputs? if not, any recommendations? Also the outputs must be able to throw in mono.
Thanks for your help!
James
cheims is offline
post #2 of 3 Old 09-02-2015, 07:57 AM
RayDunzl's Avatar
Quoted: 1022 Post(s)
Liked: 1203
If no answer here, send your question to these guys:
https://minidsp.desk.com/customer/portal/emails/new
One of their devices might be made to work in that manner.
I'll be back later...
System links::: 1.5RQ > digits from all sources > 1177a > OpenDRC-DI > DEQ2496 > DAC2 > KCT > FPB 350mcx > reQuest + Cheezewoofer Wattless Deluxe > Sweetspot
RayDunzl is online now
post #3 of 3 Old 09-02-2015, 11:52 AM
DonH50's Avatar
Quoted: 772 Post(s)
Liked: 549
There are many mixers with four (or more) outputs, but it sounds like what you really need is something with four tone control circuits. What is driving the power amp, can it be made to work? In the past I have built tone control circuits for things like this but I do not know if there are commercial products. You could but a couple of cheap stereo equalizers and patch them in before the power amps, something like this: http://www.sweetwater.com/store/detail/215S
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
equalizer , inverted mixer
